205 diesel temp light
Alex (FTS)
PostPosted: Wed Apr 04, 2007 3:30 pm    Post subject: 205 diesel temp light Reply with quote
Hello hello. I was wondering if any one could help me out. I've just got me girlfriend a tidy little pug 205 diesel van as a little runner about and it runs drives really well and we're pretty pleased with it. The one thing though that is puzzling me is that the little temp symbol (Right of the indicator symbol on the dash) flashes on quite regularly?
The rad looks mint and there does seem to be any leeks and the header tank is full! Infact the only exlanashion I could think of was that there is too much water in the header tank so it is tripping the sensor sooner????
Oh yer heating works great too and the fans come on.
Can any one help?
Alex
www.faltownskateboards.com
PostPosted: Wed Apr 04, 2007 3:44 pm    Post subject: Reply with quote
Disconnect the bulb
Pugs and electrics
famous phil
PostPosted: Wed Apr 04, 2007 10:24 pm    Post subject: Reply with quote
Hello does this 205 have a temp gauge as well as the warning light ,,, if not i would get one to be on the safe side about 30quid which is far cheaper than if it overheats ,,,, look on the thearmostat housing there should be a sensor sometimes two one = sometimes a no water sensor ,,,,,,,,,another to turn the fan ( if not one on the rad ) sometimes there might be a blanking plug where you can put sender for a temp gauge ,,,,,,,, also check behind the offside front wheel above crank pulley steel water pipe can rust badly , you might find plastic cover hiding it
Alex (FTS)
PostPosted: Thu Apr 05, 2007 10:28 am    Post subject: Reply with quote
Nice one guys. Yer strangly enough the car doesn't have a temp gaauge which I thought was very strange!!
I think I will just add another temp gauge that way we know what is truely going on. Oh I'll also check that metal pipe.
Thanks again.
famous phil
PostPosted: Thu Apr 05, 2007 8:29 pm    Post subject: Reply with quote
Hello thought that would be right ,,,,, often to late by the time a bleedin light comes on ,
KEITHC
PostPosted: Sun Apr 15, 2007 7:06 pm    Post subject: Reply with quote
Check that the radiator is not blocked (run your hand over the matrix when it has been run for a while), this is a known problem where the waterways crust up inside.
My girlfriend ran one of these quite a few years ago, and the fan hardly ever ran, so your's could be getting too hot.
