HalfMoon Padawan
Posted: Mon Jun 11, 2007 10:40 am Post subject: Engine to Rad pipe run diameter? |
Is there an optimum diameter for the pipes to and from the rad? And is copper pipe considered good or bad?
 _________________ Project Thor - '71 Fastback with an EJ20T
Alex (FTS) Jedi Guardian
Posted: Mon Jun 11, 2007 6:27 pm Post subject: |
The big it is the better cooling you will have as there is more water in the system. I've always got pipe the same size as the radiator in and out.  _________________ www.faltownskateboards.com |
rjes Jedi Guardian
Posted: Mon Jul 16, 2007 8:45 pm Post subject: |
You can't go wrong if you stick to the size VW used in the T25 - 38mm (1 1/2").
Copper is prettybad - see this page on my site http://www.rjes.com/html/material_choice.html _________________ Regards,
www.rjes.com |
