gerrelt Jedi Master
Posted: Sun Jun 10, 2007 6:21 pm Post subject: Coolant pipes |
Yesterday a testdrive ended in a clowd of steam. I turned out that a hose was blown off:
The pipe I used was too smooth (I used drainage pipe). So, learn from my mistake and don't use smooth pipes.
You live, you learn. _________________ homepage
VolksRomeo 13033 S 1.4 IE
_________________ |
Posted: Sun Jun 10, 2007 11:02 pm Post subject: |
You can prolly fix that.
What's the pipe made from? If it's chromed copper/brass etc.. remove the chrome with emery paper. Get some copper wire - thick electrical cable etc and wrap it tightly around the pipe to form a ring.
Apply some plumbers flux and solder it up, you now have a ridge. _________________ The advice you receive on here is worth the paper it's written on.
gerrelt Jedi Master
Posted: Mon Jun 11, 2007 6:42 pm Post subject: |
Thanx for the tip, but I am going to bin them. The (I think brass) pipes have really thin walls, so I don't trust them. The reason I used them was because they were cheap! (yeah...I'm dutch... )
I am going to use these:
But then without the little bleed-pipe.
The threaded ends should give it enough grip. But maybe I will take your tip and use it on these things to give them an ridge.
I allready used these on the radiator side of the hoses.
These things are 10 euro's a piece...  _________________ homepage
_________________ |
doppelganger Jedi Guardian
Posted: Mon Jun 11, 2007 6:52 pm Post subject: |
just dont use to many or you can seriously cut down the flow  _________________ vwdrc class rep
Posted: Mon Jun 11, 2007 10:01 pm Post subject: |
Can you get curved ones? They're far better for flow and will last longer.
What diameter are they?
If you can find some in aluminium a decent car place or engineering company could roll you a swage in. _________________ The advice you receive on here is worth the paper it's written on.
gerrelt Jedi Master
Posted: Sun Jun 24, 2007 7:18 pm Post subject: |
I couldn't find any curved ones.
I used the angled ones, and brazed (=soldered?) a ridge to it:
The one on the left is allready soldered, the one on the right not yet.
And installed & filled:
After quite a bit of km's it's still holding.
Thanks for the tip, ElusiveStranger! _________________ homepage
_________________ |
Posted: Sun Jun 24, 2007 9:20 pm Post subject: |
Glad you're back up and running  _________________ The advice you receive on here is worth the paper it's written on.
