Posted: Mon Jun 18, 2007 7:21 pm Post subject:
anyone remember FSO polenzia or somet like that they also used peugeot diesel engines rear wheel drive , not seen one for a long time ,,,, 1996'ish _________________ Auto Union Munga Jeep ,T4 2.4td , T4 2.5tdi ,Mercedes S Class on LPG , 66 splity deluxe , GP mk1, 3 type 25s 1 with 1.9dt pug engine + 1 with N/A pug engine ,,there are 6 t25s with pug power in Darlington
Posted: Mon Jun 18, 2007 8:23 pm Post subject:
no but what i can remember the engine sat at the same sort of angle as the pug engine sits in a bus had a look on ebay , not much on there ,,,,,,,
Quote '' Anyone got a wiring diagram for a 1996/7 1.9 DT xantia engine bay ? '' think you'd be best making your own , to join up to the bus loom ,,, adding the fan wires 'n' relays i used the full lot from a 405d 1 heavy live and 1 heavy earth wire was all that was needed _________________ Auto Union Munga Jeep ,T4 2.4td , T4 2.5tdi ,Mercedes S Class on LPG , 66 splity deluxe , GP mk1, 3 type 25s 1 with 1.9dt pug engine + 1 with N/A pug engine ,,there are 6 t25s with pug power in Darlington
Posted: Mon Jun 18, 2007 8:36 pm Post subject:
Phil
Yes all wiring is in two speed twin fans ect, What I am looking for is the wiring control for the pump advance , if I put 12v + to it, engine runs smoother on tickover but after 20 or 30 seconds it start mis a bit. I have a diagram for 1994 and have wired up as that, but the xantia pump was later type so I just wanted to see a later Diagram.
Posted: Mon Jun 18, 2007 8:50 pm Post subject:
well den a think the might be a diagram on the web as ppl have pointed this out to me regarding other vehicles ,,,, i've tried running with a live running from the main fuel shut off valve to the '' pump advance '' was not sure if thats what it was or exess fuel ,, never thought it made any difference , so just ran it without _________________ Auto Union Munga Jeep ,T4 2.4td , T4 2.5tdi ,Mercedes S Class on LPG , 66 splity deluxe , GP mk1, 3 type 25s 1 with 1.9dt pug engine + 1 with N/A pug engine ,,there are 6 t25s with pug power in Darlington
Posted: Mon Jul 02, 2007 9:00 pm Post subject:
i just wire up whats there vdub to pug then make the rest up ,, top tip run a trailer flex from the cab to the engine bay _________________ Auto Union Munga Jeep ,T4 2.4td , T4 2.5tdi ,Mercedes S Class on LPG , 66 splity deluxe , GP mk1, 3 type 25s 1 with 1.9dt pug engine + 1 with N/A pug engine ,,there are 6 t25s with pug power in Darlington
