PUG 1.9 TD in type 2 someone most have one come on lets see
Goto page Previous  1, 2, 3
famous phil
PostPosted: Mon Jun 18, 2007 7:21 pm    Post subject: Reply with quote
Hello anyone remember FSO polenzia or somet like that they also used peugeot diesel engines rear wheel drive , not seen one for a long time ,,,, 1996'ish
den
PostPosted: Mon Jun 18, 2007 8:01 pm    Post subject: Reply with quote
Hello
pepper
The air filter housing is vw but off a later bay just fitted in well.
Phil
I do Yes they did a pickup truck, what are you saying my Vpug is beginning to look like one ?
Anyone got a wiring diagram for a 1996/7 1.9 DT xantia engine bay ?
famous phil
PostPosted: Mon Jun 18, 2007 8:23 pm    Post subject: Reply with quote
Hello no but what i can remember the engine sat at the same sort of angle as the pug engine sits in a bus Happy had a look on ebay , not much on there ,,,,,,,
Quote '' Anyone got a wiring diagram for a 1996/7 1.9 DT xantia engine bay ? '' think you'd be best making your own , to join up to the bus loom ,,, adding the fan wires 'n' relays i used the full lot from a 405d 1 heavy live and 1 heavy earth wire was all that was needed Grin
den
PostPosted: Mon Jun 18, 2007 8:36 pm    Post subject: Reply with quote
Hello Phil
Yes all wiring is in two speed twin fans ect, What I am looking for is the wiring control for the pump advance , if I put 12v + to it, engine runs smoother on tickover but after 20 or 30 seconds it start mis a bit. I have a diagram for 1994 and have wired up as that, but the xantia pump was later type so I just wanted to see a later Diagram.
famous phil
PostPosted: Mon Jun 18, 2007 8:50 pm    Post subject: Reply with quote
Hello well den a think the might be a diagram on the web as ppl have pointed this out to me regarding other vehicles ,,,, i've tried running with a live running from the main fuel shut off valve to the '' pump advance '' was not sure if thats what it was or exess fuel ,, never thought it made any difference , so just ran it without Happy
illzlee
PostPosted: Tue Jun 19, 2007 12:03 pm    Post subject: Reply with quote
ayup phil, try sear ching for an fso polonez on fleabay - doubt there will be many left as i seem to remember top gear hated them as much as caravans!
den
PostPosted: Sun Jul 01, 2007 7:51 pm    Post subject: Reply with quote
den wrote:
Hello
pepper
Phil
Come on someone must have a wiring diagram for a 96/97 1.9 DT xantia or 306/406 engine bay.
Thanks Den
pepper
PostPosted: Mon Jul 02, 2007 6:17 pm    Post subject: Reply with quote
shall check my extensive Haynes manual collection this evening for you.
famous phil
PostPosted: Mon Jul 02, 2007 9:00 pm    Post subject: Reply with quote
Hello i just wire up whats there vdub to pug then make the rest up ,, top tip run a trailer flex from the cab to the engine bay Grin
pepper
PostPosted: Mon Jul 02, 2007 10:01 pm    Post subject: Reply with quote
Had a look through my manuals tonight and can't find the Xantia one, someones borrowed it and not returned it I'm afraid.
den
PostPosted: Mon Jul 02, 2007 10:07 pm    Post subject: wiring Reply with quote
Hi Hello Pepper
Thanks for having a look anyway.
Phil your T25 looking great, nice one.
Den
Page 3 of 3
