evercold Padawan
Posted: Wed Jul 04, 2007 8:54 pm Post subject: any one got any diagrames/pics of a bay cooling system |
hi peps putting a ej22 in my bay got a xj40 rad mounted underneath,just wondered how anyone else has done this ie how the mounted expansion chamber, also the rad has an over flow (8mm pipe coming off the top ) dose this work like the subaru (when it reaches a 16psi it lets by).
any info would be great
thanks evercold
Posted: Wed Jul 04, 2007 11:04 pm Post subject: |
Have a looksee at my posts in here (My conversion PTI thro PTIV), you won't have to guess anything!
There's also shots in "Show us your rads - Buses" and my header tank (Vauxhall Fronteria)
My 8mm goes to the header. It isn't pressure controlled.
Make sure the header is a 'flow through' one. Mine's in the heater line, if you use a single feed tank you get vapor locking (mine was living proof and so was Kev's) _________________ The advice you receive on here is worth the paper it's written on.
evercold Padawan
Posted: Thu Jul 05, 2007 2:44 pm Post subject: |
cheers elusive i will have a look  |
Posted: Thu Jul 05, 2007 3:44 pm Post subject: |
You should've come to Expo
I'm going to be passing Dartford on Sunday (weather permitting) to go to Splitterz in Essex if you want a gander. _________________ The advice you receive on here is worth the paper it's written on.
evercold Padawan
Posted: Thu Jul 05, 2007 4:18 pm Post subject: |
i would love to to have a gander but the mrs is DRAGGING me to liverpool this week end to see the in laws i recon i should have it up and running in two weeks then i can get back going to the shows , il let you when its up and running if you passing in the mean time give us a shout the kettels always warm in my house. |
