Joined: 19 Dec 2006 Posts: 20 Location: nimes south of france
Posted: Wed Jul 11, 2007 4:43 am Post subject: synch ECU=>key
hello;
for my bug, i've bought a EJ20T from a 04 WRX subaru...
the pb is that a friend tryed put all my stuff (ecu, transponder and his key) in his subaru that have the same ref of ecu
the car start, idle 1 second and stop...
with all his things, work perfectly...
so we think of a pb of synchro between the key and ECU...
i read somewhere it sometimes happend when key is not used for long time...
does anybody know any procedure to synch all together...?i know it exist in subaru concession, but i can't go with only the ecu and key, they will look me
You need your transponder for your ECU. (Is you post a typo?)
Scoobies run for approx 1 sec then die if the ECU can't see the correct transponder. Once they're started you can remove the transponder.
Mine (98 EJ20) doesn't like the transponder taped onto the aerial. I taped it to a large screwdriver, wrapped in pipe lagging, then stuffed into the aerial. _________________ The advice you receive on here is worth the paper it's written on.
Posted: Thu Jul 12, 2007 4:20 am Post subject: Re: synch ECU=>key
ElusiveStranger wrote:
1303RSII wrote:
hello;
yes every time we had put the transponder correspondant to the ecu...
