Engine to Rad pipe run diameter?
HalfMoon
PostPosted: Mon Jun 11, 2007 10:40 am    Post subject: Engine to Rad pipe run diameter? Reply with quote
Is there an optimum diameter for the pipes to and from the rad? And is copper pipe considered good or bad?
Project Thor - '71 Fastback with an EJ20T
Welding
PostPosted: Mon Jun 11, 2007 6:27 pm    Post subject: Reply with quote
The big it is the better cooling you will have as there is more water in the system. I've always got pipe the same size as the radiator in and out.
PostPosted: Mon Jul 16, 2007 8:45 pm    Post subject: Reply with quote
You can't go wrong if you stick to the size VW used in the T25 - 38mm (1 1/2").
Copper is prettybad - see this page on my site http://www.rjes.com/html/material_choice.html
