T25 Auto
Goto page Previous  1, 2
mr bricolage
PostPosted: Wed Jul 25, 2007 11:52 am    Post subject: Reply with quote
Auto conversion here
pepper
PostPosted: Wed Jul 25, 2007 4:55 pm    Post subject: Reply with quote
sorry we can't get into your link as it needs a password to get into.
Any other way of showing us your T25 auto?
Trent
PostPosted: Wed Jul 25, 2007 9:56 pm    Post subject: Reply with quote
Is that the one from the little insert in Ultra last month?
Trent
PostPosted: Wed Jul 25, 2007 10:35 pm    Post subject: Reply with quote
Hmmm there is a slight consensus towards an auto if a big engine is used years ago i had a 2.5 e30 bmw with an auto box which i had no complaints about. suppose it will need a cooler though if i go that way.
Right now i need to find the fault with it.
mr bricolage
PostPosted: Thu Jul 26, 2007 10:24 am    Post subject: Reply with quote
Yes it was in Ultra VW. As far as the password is concerned. Why not register.
Trent
PostPosted: Thu Jul 26, 2007 11:41 am    Post subject: Reply with quote
I would agree with that! Loads of information and more people who have done conversions.....
PostPosted: Tue Jul 31, 2007 10:12 pm    Post subject: Reply with quote
Something else you may want to bear in mind is the difference in rev range between VW and Subaru flat 4's. Any Subaru engiune will rev to at least 6250rpm - considerably more than a VW engine. I have no experience with auto's but did read somewhere that the shift points on the VW auto system ate all effectively too low when a Subaru engine is fitted, but that they can be modified by an auto box expert. No idea how, or bu who, but I guess there is some sort of mechanical 'govenor' which measures the negine speed to determine when to shift, and that this can somehow be modified. The subaruvanagon Yahoo group ought to have more info, as theyhave far more auto's in the US than we do.
Trent
PostPosted: Wed Aug 01, 2007 9:14 am    Post subject: Reply with quote
Cheers RJ, I would like to use your kit but not sure of all the work. On the govner side of things. you are correct in your assumption. on the side of the box ther is a mechanical gov'ner. when you get the kit from KEP they send you a diagram of how to adapt the little arms in the jobbie.
If you are interested have a look at this.
http://www.weidefamily.net/vanagon/HTML/09/02/slideshow.html
Page 2 of 2
