evercold Padawan
Posted: Thu Aug 02, 2007 6:29 pm Post subject: alternator probs |
hello everyone,my battery wasnt charging checked my alternator and it was pushing out 10v ,so i brought a new one just put it one and its doing the same only 10v , i havent got my alternator light connected(wasnt one on the vdub engine) would this cause this. if not any one got any clues.
thanks |
ricola Jedi Master
Posted: Thu Aug 02, 2007 9:46 pm Post subject: |
Some alternators have to have the charge light hooked up to allow charging, definitely sounds like that's the case!
Posted: Thu Aug 02, 2007 10:02 pm Post subject: |
Fully charge your battery first, around 13V before doing anything else.
Check earth straps:
1/ Gear box to chassis
2/ Battery earth to chassis
3/ Engine to battery earth (I really must do this!)
Do you mean "Brand spanking new"? If so it sounds like you're not getting enough excitation voltage.
This looks like it's a pretty good read:
http://www.forparts.com/ICsubaruelectricalsystem11.05.htm
Not having a charge light is a BadThing(TM) especially on a dub! (Light comes on and it could have told you your alt belt had snapped and you've lost all cooling)
They're easy enough to wire up - do it. It's two wires and a bulb - POP.
No, not having one wouldn't cause this problem. _________________ The advice you receive on here is worth the paper it's written on.
Alex (FTS) Jedi Guardian
Posted: Fri Aug 03, 2007 9:24 am Post subject: |
Yer I have had the same proble, and It was because the alternator would not charge properly with out thr alternator light being connected.  _________________ www.faltownskateboards.com |
evercold Padawan
Posted: Fri Aug 03, 2007 11:06 am Post subject: |
thnaks peps iv been told that the bottom left terminal on the alternator is the charge light is this right, my batterys dead so i will give that a charge and check my earths, what light on the dash is the alternator is it the "G" red light.
thanks matt
ps. elusive year brand spanking new  |
Posted: Fri Aug 03, 2007 12:53 pm Post subject: |
JP, Ricola - thanks for that guys, live and learn
Evercold, sorry for the duff gen. _________________ The advice you receive on here is worth the paper it's written on.
evercold Padawan
Posted: Fri Aug 03, 2007 3:26 pm Post subject: |
just to let you know you need you alternator light connected for your alternator to work,any one want a new alternator for a ej 22
thaks peps you make this a whole lot easyer  |
evercold Padawan
