help, mods move if not acceptable here, input shaft help req
toadheaddesigns
PostPosted: Sun Aug 05, 2007 11:47 am    Post subject: help, mods move if not acceptable here, input shaft help req Reply with quote
doing my fuckin head in now
i have changed the shaft and rescrewed it to the front shaft, but i cant get the gear muff to slide forward at all now...when i took it apart it came away really easy
the gear muff seems to be catching on the diff.
is there any way to resolve this other than taking the other side cover off and removing the diff
gearbox is still in the feckin car
i am just getting concerned that i might be damaging the diff or the muff gear
pics below
any help appreciated
or should i have done it from the diff side in the first place????
fuckin car
"Doc I can't stop singing The Green, Green Grass of home"
"Is it common?"
"It's not unusual."
72panelvan
PostPosted: Sun Aug 05, 2007 12:17 pm    Post subject: Reply with quote
can you unscrew it slightly to line up the splines?
toadheaddesigns
PostPosted: Sun Aug 05, 2007 1:10 pm    Post subject: Reply with quote
tried but the muff gear is catching on the diff. i think this is the problem, i dont want to try and use a drift and tap the muff down the spline in case of damage. that is assuming the splines are lined up
"Is it common?"
"It's not unusual."
toadheaddesigns
PostPosted: Mon Aug 13, 2007 5:36 pm    Post subject: Reply with quote
done...finally
all back together now, just ned to put new bearing on the axle and then put the hubback on...then its engine in time!!!!!
"Is it common?"
"It's not unusual."
PostPosted: Tue Aug 14, 2007 10:17 am    Post subject: Reply with quote
Well done fella-I had exactly the same problem when doing mine-problem is I cant remember what I did!
