Radiator Archive - Show Us Pics of Your Rads Please (BUGS)
PostPosted: Thu Feb 02, 2006 10:34 am    Post subject: Radiator Archive - Show Us Pics of Your Rads Please (BUGS) Reply with quote
I am going to keep this thread as a Sticky containing pictures of weird and wonderful radiator set-ups.
I will post Pics of any I find knocking around the web hope I don't offend any of the owners of said vehicles if I do please let me know and I will remove them.
Please Post your pics or describe your set-up here.
gerrelt
PostPosted: Tue Feb 07, 2006 6:52 pm    Post subject: Reply with quote
Hi,
I am gonna try to put the radiator in the rear parcel shelf:
(Yeah, I know, even a five year old kid can draw a better picture... :smt001 )
I'm not sure about the angle of the radiator, it might become less lying down.
This part of my site tells the whole story:
http://home.tiscali.nl/~gmolhoek/alfa/radiator/index.htm
Greetings,
Gerrelt.
PostPosted: Fri Feb 10, 2006 4:05 pm    Post subject: Problem Solved Reply with quote
Here is the answer you bug lot have been looking for
ricola
PostPosted: Tue Feb 14, 2006 9:32 am    Post subject: Reply with quote
Pace race spec radiator for sierra cosworth with chargecooler rad in front.
Rich
http://www.ricola.co.uk
dubber91
PostPosted: Fri Feb 24, 2006 10:59 pm    Post subject: Reply with quote
Go to www.nfauto.co.uk (CBS part) and buy an adjustable thermostat for the fan...best thing i ever bought. Can set the temp the fan comes on at Happy
around £30
PostPosted: Tue Mar 28, 2006 1:59 pm    Post subject: Reply with quote
Must be a popular look Grin
PostPosted: Fri Sep 21, 2007 8:05 pm    Post subject: Link to SubaruBoxer's on Aussies Reply with quote
You have to register to see the images
http://forums.aussieveedubbers.com/viewtopic.php?tid=35720#pid357481
baja bug
PostPosted: Wed Dec 19, 2007 8:48 pm    Post subject: Reply with quote
i put my rad in the extended rear baja cage and i,ve had no temperature problems at all but you can only do this with the back of the car removed
(yes the rad is upsidedown but it still works fine)
AMBROSIA
PostPosted: Thu Dec 20, 2007 2:18 pm    Post subject: Reply with quote
My project is pretty much done (when I sort out the carb problems that is )
Here are some pictures of the cooling system:
Interior Heating:
The engine:
In this weather it sit's at 70 degrees constantly when driving.
gerrelt
PostPosted: Thu Dec 20, 2007 4:12 pm    Post subject: Reply with quote
Nice job!
AMBROSIA wrote:
How did you create these holes? What tools did you use?
homepage
VolksRomeo 13033 S 1.4 IE
AMBROSIA
PostPosted: Fri Dec 21, 2007 10:00 pm    Post subject: Reply with quote
First I made a template with a cutout.
Then taped a bit of string so that showed the correct curve.
Then I sprayed, note the guide line on the template to get the spacing correct.
Next up the drill.
After using a jigsaw and a set of files.
Came out better than I expected.
gerrelt
PostPosted: Sat Dec 22, 2007 9:02 am    Post subject: Reply with quote
Yep, it looks really good!
Thanks.
homepage
