MGF water pipes
Rapidresto
PostPosted: Mon Nov 19, 2007 11:43 am    Post subject: MGF water pipes Reply with quote
Anyone used them? they are steel with a 32mm dia and about 160cm long.
I'm thinking that they might be a neat 'factory' style solution to getting coolant from my ej20 to the radiator in the front of my ghia.
illzlee
PostPosted: Mon Nov 19, 2007 12:48 pm    Post subject: Reply with quote
could be a nice cheap way of getting long coolant hoses, how long are they?
Rapidresto
PostPosted: Mon Nov 19, 2007 1:15 pm    Post subject: Reply with quote
160cm long, welded tabs keep them together and provide a fixing point, have bulges on the ends to stop the pipes blowing off.
PostPosted: Mon Nov 19, 2007 1:27 pm    Post subject: Reply with quote
fantastic idea! plenty in the scrappies too!
heres a pic I found of some.....
PostPosted: Mon Nov 19, 2007 5:20 pm    Post subject: Reply with quote
been using them for yrs Grin seperate them and turn one outlet to face other way ,less bends needed for rad hookup Wink
Rapidresto
PostPosted: Mon Nov 19, 2007 5:30 pm    Post subject: Reply with quote
cool how is the length on a bug? and i presume you are using the bent ends at the front for the rad?
PostPosted: Mon Nov 19, 2007 5:35 pm    Post subject: Reply with quote
its good for a bug bent ends at the front Wink
72panelvan
PostPosted: Mon Nov 19, 2007 6:35 pm    Post subject: Reply with quote
good spot! are the walls pretty thick? only reason I ask is they are the perfect length and diameter for my set up but i'd need to bend them to shape in a few places. my mates dad own's a plumbing business so got access to the right tools.
tom
