Rapidresto Initiate Jedi
Joined: 17 Sep 2007 Posts: 36 Location: Enfield and Shropshire
Posted: Mon Nov 19, 2007 11:43 am Post subject: MGF water pipes |
Anyone used them? they are steel with a 32mm dia and about 160cm long.
I'm thinking that they might be a neat 'factory' style solution to getting coolant from my ej20 to the radiator in the front of my ghia.
illzlee Jedi Master
Posted: Mon Nov 19, 2007 12:48 pm Post subject: |
| could be a nice cheap way of getting long coolant hoses, how long are they? |
Posted: Mon Nov 19, 2007 1:15 pm Post subject: |
| 160cm long, welded tabs keep them together and provide a fixing point, have bulges on the ends to stop the pipes blowing off. |
Posted: Mon Nov 19, 2007 1:27 pm Post subject: |
fantastic idea! plenty in the scrappies too!
heres a pic I found of some.....
doppelganger Jedi Guardian
Posted: Mon Nov 19, 2007 5:20 pm Post subject: |
been using them for yrs seperate them and turn one outlet to face other way ,less bends needed for rad hookup  _________________ vwdrc class rep
Posted: Mon Nov 19, 2007 5:30 pm Post subject: |
| cool how is the length on a bug? and i presume you are using the bent ends at the front for the rad? |
Posted: Mon Nov 19, 2007 5:35 pm Post subject: |
| Rapidresto wrote: | | cool how is the length on a bug? and i presume you are using the bent ends at the front for the rad? |
its good for a bug bent ends at the front  _________________ vwdrc class rep
72panelvan Jedi Master
Posted: Mon Nov 19, 2007 6:35 pm Post subject: |
good spot! are the walls pretty thick? only reason I ask is they are the perfect length and diameter for my set up but i'd need to bend them to shape in a few places. my mates dad own's a plumbing business so got access to the right tools.
tom |
