'71 Scoobybus 2.0T mid-engine
Goto page 1, 2, 3  Next
scoobybus
PostPosted: Thu Jan 17, 2008 11:47 am    Post subject: '71 Scoobybus 2.0T mid-engine Reply with quote
Hello ,
Finally found some time to post some pics ...
I was searching @ google and came again to this site Happy
So I am kevin , 26y , From Belgium between Antwerp & Brussels.
I have this baywindow approx 6years , I've had a few other aircooleds : T2a single cab(sold) , 65 bug speedster (sold) and now I cruising a 56 oval bug.
Daily driver is a new beetle 1.8t , chip , exhaust , dumpvalve .... Wink
Enough about me , here some specs & pics ...
Engine EJ20 T , no cat , custom made exhaust , australian chip = approx 280hp
5-speed subaru gearbox
Top speed 225km/h (140MPH)
Best 0-100km/h (62MPH) 5.7sec
Best 1/4mile 14.3sec @ 155km/h (97MPH)
PostPosted: Thu Jan 17, 2008 12:16 pm    Post subject: Reply with quote
Hello
You must be the man who inspires a lot of people on this forum.... you'll find one or two of your videos on here Grin
Great to have you onboard at last Grin
Pad
PostPosted: Thu Jan 17, 2008 1:09 pm    Post subject: Reply with quote
that is a sweet ride.. respect!
PostPosted: Thu Jan 17, 2008 1:42 pm    Post subject: Reply with quote
welcome - im glad you made it here at last. Hello Fantastic van and an inspriation to many...any watercooled plans for the Oval? I used to have a '55 and that 30hp engine was painfully slow....
PostPosted: Thu Jan 17, 2008 6:49 pm    Post subject: Reply with quote
Hello Welcome to the "nut house"
Did you do it yourself?
I haven't seen a radiator set up like that before! But there again we all gearboxes in the way!
Do you use a scoop under the van to get cool air up to it?
Are the fans on most of the time?
Would love to see some photos of the gearbox & engine from underneath Happy
PostPosted: Thu Jan 17, 2008 9:43 pm    Post subject: Reply with quote
Sweeet sweet ride-yes yes yes need more info on it-Engine and gearbox togeth definatly seem the way forward. Eeeek
scoobybus
PostPosted: Thu Jan 17, 2008 10:32 pm    Post subject: Reply with quote
I will make some engine/gearbox/suspension pics soon ...
I've did the conversion with my dad Happy
Yes there is a scoop underneath the van ... Fans not running all the time ..
If you run +120MPH then they work , but engine temp stays fine ..
Rad & fans are from a subaru turbo Wink
@ rich , yep still cruising around with the original 1200 30hp , but powered by a judson compressor Wink 50hp Grin but fast enough for my very low ovali Cool
greets
Kevin
PostPosted: Thu Jan 17, 2008 10:40 pm    Post subject: Reply with quote
Nice going Kev.
I did notice it was a Scooby turbo rad with the 2x twin speed fans.
120 mph before the fans start running - gotta see more of this cooling system. What was the outside temp for these conditions?
I think you owe your dad a beer or two Happy
scoobybus
PostPosted: Thu Jan 17, 2008 10:44 pm    Post subject: Reply with quote
In Belgium max temp in summer is approx 25°C , most of the time its between 12 & 20°C , if temp is under 20°C cooling may not be a problem.
PostPosted: Thu Jan 17, 2008 11:52 pm    Post subject: Reply with quote
I am a bit about your bus it has early bay front, early bay rear lights but big vents ! ie not moon vents.. Eeeek
Have you changed the vents or the rear lights or is this another incarnation from the VW factory using bits up !
Have to say it is one sweet bus
scoobybus
PostPosted: Fri Jan 18, 2008 11:10 am    Post subject: Reply with quote
JP its an early 71 , it was indeed with the T2B rear lights Sad so we changed that ! I prefer the small T2a vents , but thes are bigger and more effective , so they stayed like they were ...
PostPosted: Fri Jan 18, 2008 11:32 am    Post subject: Reply with quote
Interesting.. I recall Covin was thinking of doing this to his bus and we all said it wouldn't work.. I guess we were wrong Grin
Get yer grinder out Covin Grin
Page 1 of 3
