Posted: Thu Feb 02, 2006 10:34 am Post subject: Radiator Archive - Show Us Pics of Your Rads Please (BUGS) |
I am going to keep this thread as a Sticky containing pictures of weird and wonderful radiator set-ups.
I will post Pics of any I find knocking around the web hope I don't offend any of the owners of said vehicles if I do please let me know and I will remove them.
Please Post your pics or describe your set-up here. _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
2013 Scirocco TDI GT |
gerrelt Jedi Master
Joined: 07 Feb 2006 Posts: 354 Location: the Netherlands
Posted: Tue Feb 07, 2006 6:52 pm Post subject: |
Hi,
I am gonna try to put the radiator in the rear parcel shelf:
(Yeah, I know, even a five year old kid can draw a better picture... :smt001 )
I'm not sure about the angle of the radiator, it might become less lying down.
This part of my site tells the whole story:
http://home.tiscali.nl/~gmolhoek/alfa/radiator/index.htm
Greetings,
Gerrelt. |
ricola Jedi Master
Posted: Tue Feb 14, 2006 9:32 am Post subject: |
Pace race spec radiator for sierra cosworth with chargecooler rad in front.
Rich _________________ http://www.ricola.co.uk |
dubber91 Initiate Jedi
Joined: 24 Feb 2006 Posts: 31 Location: portsmouth/bedford/hatfield
Posted: Fri Feb 24, 2006 10:59 pm Post subject: |
Go to www.nfauto.co.uk (CBS part) and buy an adjustable thermostat for the fan...best thing i ever bought. Can set the temp the fan comes on at
around £30 |
Posted: Fri Sep 21, 2007 8:05 pm Post subject: Link to SubaruBoxer's on Aussies |
You have to register to see the images
http://forums.aussieveedubbers.com/viewtopic.php?tid=35720#pid357481 _________________ The advice you receive on here is worth the paper it's written on.
baja bug Force Sensitive
Posted: Wed Dec 19, 2007 8:48 pm Post subject: |
i put my rad in the extended rear baja cage and i,ve had no temperature problems at all but you can only do this with the back of the car removed
(yes the rad is upsidedown but it still works fine)
AMBROSIA Initiate Jedi
Joined: 10 Jul 2007 Posts: 31 Location: Wickford, Essex
Posted: Thu Dec 20, 2007 2:18 pm Post subject: |
My project is pretty much done (when I sort out the carb problems that is )
Here are some pictures of the cooling system:
Interior Heating:
The engine:
In this weather it sit's at 70 degrees constantly when driving. |
gerrelt Jedi Master
Posted: Thu Dec 20, 2007 4:12 pm Post subject: |
Nice job!
| AMBROSIA wrote: |
How did you create these holes? What tools did you use? _________________ homepage
VolksRomeo 13033 S 1.4 IE
_________________ |
Posted: Fri Dec 21, 2007 10:00 pm Post subject: |
| Quote: | | How did you create these holes? What tools did you use? |
First I made a template with a cutout.
Then taped a bit of string so that showed the correct curve.
Then I sprayed, note the guide line on the template to get the spacing correct.
Next up the drill.
After using a jigsaw and a set of files.
Came out better than I expected. |
gerrelt Jedi Master
Posted: Sat Dec 22, 2007 9:02 am Post subject: |
Yep, it looks really good!
Thanks. _________________ homepage
_________________ |
