Gear linkage
Post new topic   Reply to topic     Forum Index -> Volks Power
KARMAD
PostPosted: Tue Feb 24, 2015 2:03 pm    Post subject: Gear linkage Reply with quote
Hi lads just wondering does anyone on here have info or pictures of there gear linkage from tdi passat flipped box in a bay or split as this is puzzling me
PostPosted: Tue Feb 24, 2015 2:17 pm    Post subject: Reply with quote
Basically there are 2 ways of doing it.
1: use cables. Porsche boxter will happily provide you with parts. See this thread:
http://vwkd.com/bb/viewtopic.php?t=302&postdays=0&postorder=asc&start=156
2: use the more-or-less stock rod system. Just connect the rod that went to your original box, to the little rod sticking out of the TDI box. like this:
http://www.furgovw.org/index.php?topic=238716.195
or this:
http://www.youtube.com/watch?feature=c4-feed-u&v=KWH-NRkpzUo&app=desktop
The cables work, but they are stiff so you cannot easily work them out of your sight and you will get a sort of column between the two front seats on which you have to mount the gear selector.
The rod system works, you get to keep original gear selector, but you might get a wrong shifting pattern. I havent read any comments on that. I am busy getting this working, and will post updates in my build thread.
PostPosted: Tue Feb 24, 2015 7:50 pm    Post subject: Reply with quote
Ultimate engineering will sell you a cable shifter kit. It's mostly designed for a T25 however they sell the bits separately so you could pick and choose the parts you could adapt to fit your bus.
KARMAD
PostPosted: Tue Feb 24, 2015 8:57 pm    Post subject: Reply with quote
Cheers lads No:2 connecting the rod to the box looks like its easy plus with a bit of work it could be raised and tightened up with maybe a u joint or something
PostPosted: Wed Feb 25, 2015 8:31 am    Post subject: Reply with quote
Hello,
yes, I used a double joint and that works well. One problem I encounterd is the lengt of the shift. You need to adjust the floorplate of the gear selector to increase the length it can move cause otherwise it is just not enough for the passat box.
I really prefer the rod linkage option over cables. I have never seen a cable setup I really like, as in most cases you would loose the walkthrough.
I desperately want to work on the bus again and than I can show some pics.
trev
PostPosted: Wed Feb 25, 2015 8:29 pm    Post subject: Reply with quote
has nobody thought to mount the cable shifter base under the cab floor with just the gear stick poking up through, like the stock shifter?
PostPosted: Wed Feb 25, 2015 10:36 pm    Post subject: Reply with quote
My guess is not, however the toyota MR2 shifter would lend itself nicely to this. My only concern would be the throw of the stick.
trev
PostPosted: Wed Feb 25, 2015 11:13 pm    Post subject: Reply with quote
you'd get used to it!! How many million VW buses were built with 2 foot long gear levers with massive throws? Most people just got along with it Laugh Out Loud
doing a bit of web mining and came across these pictures of one fellas shift cable setup:
Quote:
A quick picture of the cable shift mechanism I made up. It is mocked up with zip ties until I get some longer control cables from a boat. It is functional right now and the shifts feel good and crisp.
don't know if that sheds any light on the situation but it can't hurt? Wink
trev
PostPosted: Wed Feb 25, 2015 11:20 pm    Post subject: Reply with quote
another, he got longer cables and tidied up the cable-tie arrangement from earlier!!
PostPosted: Thu Feb 26, 2015 12:04 pm    Post subject: Reply with quote
Image not visible. Only for TDI forum members...
trev
PostPosted: Thu Feb 26, 2015 1:24 pm    Post subject: Reply with quote
I've uploaded them to my photobucket and relinked them in the posts above. Should be fine now Happy
splitbusvanatic
PostPosted: Thu Feb 26, 2015 2:10 pm    Post subject: Reply with quote
trev do you have a link to this build ? thanks. Dan.
Post new topic   Reply to topic     Forum Index -> Volks Power All times are GMT
