radiator dimensions
rusty69bus
PostPosted: Sat Mar 17, 2007 9:37 am    Post subject: radiator dimensions Reply with quote
to help us all in the quest to find the best rad's for our needs..... Grin
please post dimensions of rad's you have measured or tried, with picture (if possible) or show the outlet positions, and lastly what their from.
rusty69bus
PostPosted: Mon Mar 26, 2007 7:00 pm    Post subject: Reply with quote
72panelvan
PostPosted: Fri May 11, 2007 6:20 pm    Post subject: Reply with quote
Probably a link already on here somewhere but I'm finding this place pretty useful:- http://www.radicool.co.uk/ . I think they are pics taken from nissens website but you need to log in for that. Just follow the link to radiators and theres loads of info. Then go onto ebay and they have most of them for sale on there - aluminium to boot.
Tom
rusty69bus
PostPosted: Sat May 12, 2007 6:46 am    Post subject: Reply with quote
nice this should help alot
familyvan
PostPosted: Tue May 15, 2007 2:56 pm    Post subject: Reply with quote
I found that TWO seat Toledo Rads 1.8 will fit between the chasis rail ( JUST )
PostPosted: Tue May 15, 2007 4:54 pm    Post subject: Reply with quote
Nice job have you fitted it and tryied it out yet.
PostPosted: Tue May 15, 2007 9:52 pm    Post subject: Reply with quote
That looks neat, does that mean you're gonna have 4 fans Grin you might be able to get your van to hover with them all going at the same time
PostPosted: Wed May 16, 2007 10:59 am    Post subject: Reply with quote
Golf GTI 16v 13" x 21" will also fit between chassis rails.
gerrelt
PostPosted: Wed May 16, 2007 6:17 pm    Post subject: Reply with quote
1993 Alfa Romeo 33 radiator:
Dimensions: 34 by 62 cm or 13.4 by 24.4 inch (widest points).
homepage
VolksRomeo 13033 S 1.4 IE
gerrelt
PostPosted: Tue Oct 16, 2007 6:36 pm    Post subject: Reply with quote
A great way to look up radiator sizes: click on this link. And go the the make and model you want to know the radiator size of. Click on "Radiateuren" and you'll see the dimensions (in millimeters) with the description of the radiator.
If there's a UK version of this automotive parts page, please tell!
homepage
gerrelt
PostPosted: Mon Nov 05, 2007 8:01 pm    Post subject: Reply with quote
A nice low and wide radiator from an Opel (Vauxhall) Corsa A 1.2, build somewhere around 1990:
The dimensions of the core are 53 X 23 X 3.2 cm (width X height X thick).
On widest points it is 60 X 25 cm's.
The inlet is on the top right corner in the pictures and it exits out of the side. The outlet is on the left bottom corner. These are roughly 32 mm (1 1/4 inch) connections, but it might be a little bit wider (maybe it's 33 mm).
The two "pins" sticking out of the bottom can easily be removed.
Because it is only 25 cm's high, it fits really nice into the nose of my 1303 without too much cutting.
It's probably too small for use as a primary cooler, but it might be a good choice for an additional cooler.
homepage
southcoastcruiser
PostPosted: Sun Jun 19, 2011 9:14 am    Post subject: Reply with quote
for me 2 rabbit GTI fans and radiators
2 x 525mm x 322 mm x 34mm
one of each side, in the middle of the bus
