Help identifying kit... apparently ford conversion
Goto page Previous  1, 2
Davecrook1
PostPosted: Fri Feb 11, 2011 2:51 pm    Post subject: Reply with quote
Nice one Wink
Davecrook1
PostPosted: Sat Feb 12, 2011 12:24 am    Post subject: Reply with quote
Will a sierra twin cam DOHC fit in the bay with the adapters?
Covin
PostPosted: Sat Feb 12, 2011 10:31 am    Post subject: Reply with quote
It should fit in the engine bay fine but I can't remember the component layout on this engine so you'd need to check to see if anything would be difficult to get to once installed.
Most of the Ford engines like the X-Flow, Pinto, CVH, Zetec, V4 & V6 use the shame gearbox bolt pattern
DARREN
I LOVE RUST ME
Davecrook1
PostPosted: Sat Feb 12, 2011 5:09 pm    Post subject: Reply with quote
Nice one.. There is an engine near me for sale.. Thought it might be ok.. Doesn't look anything near the flywheel.. Even the inlet manifold would face the back of the van if it was in
Shrek
PostPosted: Sat Feb 12, 2011 6:14 pm    Post subject: Reply with quote
Hi, just to chip in here - I bought an adaptor some time ago to fit a Ford motor in my bug before I decided to go with the Subaru. The bolt pattern was the same on pinto's, cvh's & zetecs, but be wary as some newer engines have engine timing(Crank) sensors fitted to the back of the block and pick up a signal from the flywheel - If the flywheel in this kit doesn't have the slots in the back for the sensor then you could end up with a lot more expense than expected!. Happy
Davecrook1
PostPosted: Sat Feb 12, 2011 6:36 pm    Post subject: Reply with quote
Good point!! Think I may stick to a pinto engine actually.. Keep it simple unless I go the scooby route
Shrek
PostPosted: Sat Feb 12, 2011 9:45 pm    Post subject: Reply with quote
If you've got the room to fit it then it's prob better as parts are cheap and they are quite robust and reliable - fit some bike carbs on a custom manifold and you should see at least 120bhp (std 2.0ltr) - thats what all the kitcar builders are doing.
Davecrook1
PostPosted: Sat Feb 12, 2011 9:59 pm    Post subject: Reply with quote
Yeah it'll fit.. But trying to decide if to go scooby or keep with the ford idea. ..
lil_azza
PostPosted: Fri Jul 29, 2011 5:03 am    Post subject: Reply with quote
Sorry to jump in but if anyone knows of a adapterplate for a ford id be greatfull for details cheers aaron
cathydeco03
PostPosted: Tue Sep 18, 2018 12:16 pm    Post subject: Reply with quote
Davecrook1 wrote:
But that unknown kit above still needs an extended input shaft? I asked the chap again and he said no Monte escalier électrique, it should just bolt up to the gearbox.. But bare in mind he hasn't fitte it to the project he was doing
But you can also see tutorials explaining the entire editing process if you really want to complete your project.
Page 2 of 2
