splitbusvanatic Jedi Master
Joined: 08 Oct 2006 Posts: 330 Location: Co. Mayo, Ireland
Posted: Thu Feb 26, 2015 4:43 pm Post subject: |
| its ok. Found it. Thanks.. |
trev Jedi Master
trev Jedi Master
Posted: Thu Feb 26, 2015 11:46 pm Post subject: |
| duh, didn't see there was a page #2!! |
rabbitboy Padawan
Posted: Sat Mar 07, 2015 4:04 pm Post subject: |
| Boxster cable shift working fine on my bay and very simple to fit. The cables are pretty flexible too and can be bent to clear things. |
skirk Jedi Knight
Joined: 05 Sep 2011 Posts: 105 Location: Leicestershire
Posted: Thu Mar 12, 2015 12:43 pm Post subject: |
| trev wrote: | | has nobody thought to mount the cable shifter base under the cab floor with just the gear stick poking up through, like the stock shifter? |
This is what I thought. Try to keep as stock as possible in looks. |
Wilfred Darth Admin
Posted: Sun Mar 22, 2015 2:13 pm Post subject: |
I finally took some pics of my setup.
See also this thread: http://vwkd.com/bb/viewtopic.php?p=31784#31784
i can select all 6 positions now, using original gear lever .5 forward, 1 reverse.
Note: I don't know how the shifting pattern turned out yet, as I havent driven it like this. But in case it turns out wrong, I have ideas on how to change that. But that will have to wait for now. _________________ 1973 BayWindow running 1.9 110 bhp TDI with flipped gearbox. |
valentind06 Wannabe
Posted: Tue Dec 18, 2018 4:24 am Post subject: |
| Wilfred wrote: | Hello,
yes, I used a double joint and that works well. One problem I encounterd is the lengt of the shift. You need to adjust the floorplate of the gear selector to increase the length it can move cause otherwise it is just not enough for the passat box.
I really prefer the rod linkage option over cables Self Stockage. I have never seen a cable setup I really like, as in most cases you would loose the walkthrough.
I desperately want to work on the bus again and than I can show some pics. |
But there are also ready-made joints that you can install without problems, you know. |
Wilfred Darth Admin
Posted: Thu Dec 20, 2018 1:26 pm Post subject: |
I did not now that. Can you show me?
oh, and it is so much more rewarding to make stuff yourself! _________________ 1973 BayWindow running 1.9 110 bhp TDI with flipped gearbox. |
