Summary Of Who's Doing What Where
RobScott
PostPosted: Fri Jan 19, 2007 11:23 am    Post subject: Reply with quote
Rob Scott
smintyfresh@hotmail.com
Preston, Lancashire
69 Baja, putting in a 2.6 V6 Vauxhall motor on trekker gearbox and reduction boxed. pleanty of torque Grin
famous phil
PostPosted: Fri Jan 19, 2007 11:31 pm    Post subject: Reply with quote
Youthy Giblets!!! wrote:
Has yours had the bottom 6 inches replaced fil?
no but mine is LHD as it came from a place where it do'nt rain ,
Mr Self Destruct
Location: Coventry - a nice place to live, but I wouldn't want to visit!
PostPosted: Fri Feb 23, 2007 8:30 am    Post subject: Reply with quote
Jonny Self Destruct
team356@btinternet.com
Coventry.
Currently building a 1967 floorpan based sandrail, with 16v gti power.
Hopfully doing this by IRS-ing the back end, fitting a late bay gearbox with a T25 Diesel bellhousing, sump etc. I'd rather go this way than an adaptor plate 'cos a) its probably cheaper, and b) it angles the engine over to the left at 45 degrees, leaving plenty of room for a rad on the right!
Once its done, I'll be blatting it round the Nurburgring for the Scumball rally! Grin
www.coventryaircooled.co.uk
but don't let the name fool you - I drive a 1984 gti and a 1998 T4, both with 140bhp!
www.scumball.co.uk - team Big Sick And Ugly!
famous phil
PostPosted: Sun Feb 25, 2007 12:39 am    Post subject: Reply with quote
Mr Self Destruct wrote:
Jonny Self Destruct
Coventry.
Hopfully doing this by IRS-ing the back end, fitting a late bay gearbox with a T25 Diesel bellhousing , sump etc. I'd rather go this way than an adaptor plate 'cos a) its probably cheaper, and b) it angles the engine over to the left at 45 degrees, leaving plenty of room for a rad on the right!
if me brother gets his strakit rail done in time with peugeot td lump i think it'll be a good one for the scumball , as it was built for the dakar rally ,
TurboBaggedWEsty
PostPosted: Wed Jul 18, 2007 7:17 pm    Post subject: Reply with quote
Email : goat_dude@msn.com
Website:
Ride : 11966 SO-42
Details:
Interior:
All original vinyl and cabinets remain from Westfalia factory in great shape. The wood for the panels was all replaced with birch, with stainless steel used as fasteners. The interior has 2 layers of Dyna/ Fatmat to quieten the bus.
Exterior:
• Has custom roof racks front and rear along with ladder, all paint matched with rubber dipped feet built by Tom Conner.
• Runs 17” Porsche Cup1 alloy rims.
• Aluminium front safari windows by Creative Engineering
• Aluminium rear safari made by Wolfgang Int.
• BB Banjo mirrors
• All new rubber seals for everything most by Wolfsburgwest.
• Lowered via 3.5 drop spindles and wolfgang swing axle kit in the rear. Also has 4 inch narrowed beam with adjusters and IT CAN GO LOWER.
• BB side step
Tranny:
Transworks tranny with Superdiff, welded 3 & 4, 3.88 r&p and bus .82 4th gear. Brand new with 2 year warranty. A Geneberg Locking shifter completes it
Engine: New
• 2110 Turbo, built for turbo by CPR:
• New case
• Static balanced
• DPR crank - tuff-trided (nitrited)
• Lightened and balanced 8 dowel flywheel
• Compression ratio 7.5 to 1
• engle tcs 10 with Norris racing lifters
• New 041 with 40x35.5 stainless steel, Tuff-trided valve's : (To increase the wear resistance of the stem and to reduce sticking) with dual springs and chromoly retainers with long reach plugs.
• Chromoly push rod's and solid rockershaft with 1.1 to 1 VW rocker arm's
• Scat I beam Rod's with APR bolts
• 3.5 qrt sump
• KEP Stage 2 Clutch
• Full Flowed HP1, with 96 plate cooler and 11inch fan. All stainless braided lines
• Runs a Holley Red fuel pump
• Optima battery
• 12v Gen
• runs 7.5 quarts of oil
• All tin paint matched
Turbo specs
AJ Simms TS system with Garret T3 turbo, Weber 40DCOE, and all ceramic coated exhaust components. Currently set at 3lbs of boost but will go higher! Happy
Suspension
Independent, remote controlled hydraulic suspension system all round. It can go from slammed to gaining 8” of height in well under 1 second!! Plus, with the remote control, you haven’t even got to be in the bus to raise/ lower it.
Ride Pro e Big Red Max
Ride Pro e Remote Control
Shockwave Bag
224c Airbag
Steering
Not the old steering box. Custom fabricated Rack and Pinion Steering system with 3 turns providing a full lock.
Brakes
Vented Cross drilled Porsche 944 brakes front and rear.
1303RSII
PostPosted: Thu Jul 19, 2007 3:48 pm    Post subject: Reply with quote
Email : 1303RSII@free.fr
Website: http://1303rs2.skynetblogs.be/
Ride : 1303 with EJ20 Turbo WRX engine
Details: Car is still in progress. Has 993 brakes, 993 cup 2 wheels, reprofiled dash for subaru instrument cluster, stock gearbox for the moment but looking ofr a 915 gearbox! , adapter kit from DS tuning
PostPosted: Thu Jul 19, 2007 9:28 pm    Post subject: Reply with quote
Email : svenne.duva@gmail.com
Website: http://vw.primenta.se
Ride : -77 T2 with a Megasquirted EJ20 (haven't decided about turbo yet), hopefully with flexifuel support. Vented discs in front and discs in the rear. Will be running next year, I think...
hege
PostPosted: Fri Nov 09, 2007 8:15 am    Post subject: Reply with quote
Website: T3 Race Taxi
Ride : T3 Transporter
Details: Making a T3 with modifications needed for race track use. Subaru ej20t mounted to a 5 speed limited slip gear box with RJES bell housing.
Also check our previous projects (sorry, only Finnish text):
Locost Yamaha R1: http://bogeyracinglocost.blogspot.com
Porsche 914 RS: http://slugmikas.blogspot.com
T3 Race Taxi
Bugsy_malone 666
PostPosted: Fri May 09, 2008 10:25 pm    Post subject: Reply with quote
Email : bugsymalone666@hotmail.com
Location : Near Basingstoke (amazingstoke as I call it lol)
Daily Ride : 94 golf Driver 1.8 (possibley convert to 5cylinder 2.4D at a later date)
Project Ride : 1972 Devon Bay
Project Plans : it started out 24 months ago as a stock bay that had been sat for 10 years with zero interior, over the past 18 months I have fully kitted it out(just need to trim the rear seat now) after spending about 9 months welding it up renewing everything, so all the running gear is new pretty much! so with fuel price going up I thought i`d get something economic to go in, ending up with a 1.6 'D' engine and gearbox in exchange for some wheels. The diesel gearbox I'm just using the bellhousing from and fitting the the stock 1600 bay gearbox. First get the lump in and sorted, then think about maybe supercharging it or something to get some more pep out of it!
Second Gear All The Way Baby!
Doing Thing Differently.
Hanger18
PostPosted: Wed Jul 23, 2008 5:04 pm    Post subject: Hotrod Bus Reply with quote
E-Mail: dh.autos@virgin.net
Rides: 1956 Chopped Supercharged V8 Pop
1956 Chopped V8 Pop
1928 Model A pick up
Project : 1962 Splitty
Details: Mid-mounted V8. Purpose built chassis on full hydraulics. Based around hotrod type suspension 4” dropped tube front, narrowed Volvo rear. Wheels American racing torq thrust 2’s 4x15 front. 8x15 rear
Punky
PostPosted: Mon Sep 08, 2008 7:34 am    Post subject: Type 2 Scooby conversion Reply with quote
Been inspired by alot on this site and i am about ready to show off what i have been up to. I have a 1975 VW Camper imported from Aus having a complete overhaul and fitting a 2lt Scooby engine. half way through installing the engine as we speak! The van is prepped for spraying the insides have been gutted. and i am so far shitting myself if it don t work!
illzlee
PostPosted: Tue Sep 09, 2008 11:22 am    Post subject: Reply with quote
E-Mail: illzlee@hotmail.com
Rides: 1979 Bay window Camper with 1.9 td (Shitroen)
Daily: 306 1.9 td or a Maroon New Bug
Past Projects: Renault 21 Turbo, Volvo 360 stripped rally sl@g
Details: Camper runs citroen 1.9 turbo diesel, connected via a famous phil adapter plate to T25 5-spd dogleg box with grafted t25 linkages. Phat tyres on audi quattro turbo rims. New interior, soon to start some panel replacement and then some new paint methinks...
after a couple of years on here it is about time i filled this in!
Page 4 of 6
