chuggaboom Jedi Master
Posted: Fri Jul 06, 2007 6:39 am Post subject: power increases |
as allways i have a million and one things going on all the time
so what can i do to increase the power on my lowly 1.9 n/a pug diesel |
pepper Jedi Knight
Posted: Fri Jul 06, 2007 4:14 pm Post subject: |
Tweak the fueling on the pump and alter the rev limiter so you can rev slightly higher.
I normally tweak the pump about 1/4 of a turn at a time until its smoking too much then back it back again slightly.
you can also alter the timing of the pump by undoing the lock nuts and twisting the pump round until it revs more smoothly. |
famous phil Jedi Guardian
Posted: Sun Jul 08, 2007 8:10 pm Post subject: |
you need one with the bocsh pump for a good start as not easy on the lucas ,,,, chuggaboom what did the engine come out of  _________________ Auto Union Munga Jeep ,T4 2.4td , T4 2.5tdi ,Mercedes S Class on LPG , 66 splity deluxe , GP mk1, 3 type 25s 1 with 1.9dt pug engine + 1 with N/A pug engine ,,there are 6 t25s with pug power in Darlington |
pepper Jedi Knight
Posted: Sun Jul 08, 2007 8:29 pm Post subject: |
| You can tweak the Lucas pump but its far harder to do, also its not as good a place to start from as a Bosch pump though. |
Posted: Mon Jul 09, 2007 12:27 pm Post subject: |
came out of a 306 will check what pump is on
i have lucas one on my turbo can i do the same with that turning the pump
i want more power
ok other than tweaking the pump any thing else i can do
maybe after this convo we could do sominstructions on the easiest way to do it and have it as a sticky in the forum |
KEITHC Wannabe
