where do you jack from ?
split_trix
PostPosted: Fri Aug 03, 2007 6:16 pm    Post subject: where do you jack from ? Reply with quote
hi, have always wondered this as many people dont trusted the stock points ...
chris
52 vwrx
PostPosted: Fri Aug 03, 2007 7:31 pm    Post subject: Reply with quote
Bug & Bus:
Front beam
Rear torsion tube ends where they join the spring plates
If I just want to raise the back of the bus (wheels still on ground) jack under the tow bar plate.
split_trix
PostPosted: Fri Aug 03, 2007 7:33 pm    Post subject: Reply with quote
sorry forgot some bits.... rear torsion tube in two pieces cos of gearbox through them.... im not sure of the strength in the ends of the tubes ?
another thing forgotten was its a bug...
cheers
52 vwrx
