scoobybus Force Sensitive
Posted: Thu Jan 17, 2008 11:47 am Post subject: '71 Scoobybus 2.0T mid-engine |
Hello ,
Finally found some time to post some pics ...
I was searching @ google and came again to this site
So I am kevin , 26y , From Belgium between Antwerp & Brussels.
I have this baywindow approx 6years , I've had a few other aircooleds : T2a single cab(sold) , 65 bug speedster (sold) and now I cruising a 56 oval bug.
Daily driver is a new beetle 1.8t , chip , exhaust , dumpvalve ....
Enough about me , here some specs & pics ...
Engine EJ20 T , no cat , custom made exhaust , australian chip = approx 280hp
5-speed subaru gearbox
Top speed 225km/h (140MPH)
Best 0-100km/h (62MPH) 5.7sec
Best 1/4mile 14.3sec @ 155km/h (97MPH)
Posted: Thu Jan 17, 2008 12:16 pm Post subject: |
You must be the man who inspires a lot of people on this forum.... you'll find one or two of your videos on here
Great to have you onboard at last  _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
2013 Scirocco TDI GT |
Pad Wannabe
Posted: Thu Jan 17, 2008 1:09 pm Post subject: |
| that is a sweet ride.. respect! |
Posted: Thu Jan 17, 2008 1:42 pm Post subject: |
welcome - im glad you made it here at last. Fantastic van and an inspriation to many...any watercooled plans for the Oval? I used to have a '55 and that 30hp engine was painfully slow.... |
Posted: Thu Jan 17, 2008 6:49 pm Post subject: |
Welcome to the "nut house"
Did you do it yourself?
I haven't seen a radiator set up like that before! But there again we all gearboxes in the way!
Do you use a scoop under the van to get cool air up to it?
Are the fans on most of the time?
Would love to see some photos of the gearbox & engine from underneath  _________________ The advice you receive on here is worth the paper it's written on.
Alex (FTS) Jedi Guardian
Posted: Thu Jan 17, 2008 9:43 pm Post subject: |
Sweeet sweet ride-yes yes yes need more info on it-Engine and gearbox togeth definatly seem the way forward.  _________________ www.faltownskateboards.com |
Posted: Thu Jan 17, 2008 10:32 pm Post subject: |
I will make some engine/gearbox/suspension pics soon ...
I've did the conversion with my dad
Yes there is a scoop underneath the van ... Fans not running all the time ..
If you run +120MPH then they work , but engine temp stays fine ..
Rad & fans are from a subaru turbo
@ rich , yep still cruising around with the original 1200 30hp , but powered by a judson compressor 50hp but fast enough for my very low ovali
greets
Kevin |
Posted: Thu Jan 17, 2008 10:40 pm Post subject: |
Nice going Kev.
I did notice it was a Scooby turbo rad with the 2x twin speed fans.
120 mph before the fans start running - gotta see more of this cooling system. What was the outside temp for these conditions?
I think you owe your dad a beer or two  _________________ The advice you receive on here is worth the paper it's written on.
Posted: Thu Jan 17, 2008 10:44 pm Post subject: |
| In Belgium max temp in summer is approx 25°C , most of the time its between 12 & 20°C , if temp is under 20°C cooling may not be a problem. |
Posted: Thu Jan 17, 2008 11:52 pm Post subject: |
I am a bit about your bus it has early bay front, early bay rear lights but big vents ! ie not moon vents..
Have you changed the vents or the rear lights or is this another incarnation from the VW factory using bits up !
Have to say it is one sweet bus  _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
Posted: Fri Jan 18, 2008 11:10 am Post subject: |
JP its an early 71 , it was indeed with the T2B rear lights so we changed that ! I prefer the small T2a vents , but thes are bigger and more effective , so they stayed like they were ... |
Posted: Fri Jan 18, 2008 11:32 am Post subject: |
Interesting.. I recall Covin was thinking of doing this to his bus and we all said it wouldn't work.. I guess we were wrong
Get yer grinder out Covin  _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
