Audi Turbo-powered T25 singlecab: stops starts and goes
Diamond Hell
PostPosted: Sat Feb 09, 2008 9:47 am    Post subject: Audi Turbo-powered T25 singlecab: stops starts and goes Reply with quote
T25 which has a 2.2 1B quattro motor fitted to it, from an Audi 200. It also has A6 288mm front brakes to reign in it's enthusiasm. The engine is fitted on a South African bellhousing and tubular mounting bar that someone (not me) made up for the 5cylinder engine. It has a 4 speed DK code lawn mower 'box which is supposed to be the strongest standard T25 gearbox available. It also has a new 240mm clutch, so that's unlikely to be found wanting.
The shell is pretty straight and relatively rot-free.
I was going to go drag racing with it, but as we're expecting our second child and I have another couple of projects, this idea is a possibility that is receding into the distance faster than a quick 1/4mile.
This wouldn't be VWDRC alt engines class, it would be Sportsman, as it's a VAG, which means you'd have something that would be fantastically competitive without spending the earth on a fandango lawn mower motor.
It runs and drives, although has no MOT at the moment. If you're interested please email on diamond.hell at gmail.com or call me on 0777 585 4268.
It and I are in Bristol. There are photos here.
This needs very little to finish, but I'm outta time.
