lowlight 185 Padawan
Posted: Wed Feb 20, 2008 7:21 pm Post subject: bits wanted |
hi folks getting some bits together to start conversion 2.2 scooby
1.flywheel
2.starter
3.bolts
4.clutch
5.fuel pump
6.throttle inverter
7.the bit that stops your cam belt jumpiing off
thats all i can think of for now thanks  _________________ Sutton in Ashfield .Nottinghamshire
home of the robin hoodys |
Posted: Wed Feb 20, 2008 7:41 pm Post subject: Re: bits wanted |
| lowlight 185 wrote: | hi folks getting some bits together to start conversion 2.2 scooby
1.flywheel - breakers or Doppleganger
2.starter - ditto
3.bolts - which bolts? Scooby main dealer, £1.50 or so each for bellhouse ones
4.clutch - friction plate? 228mm Type 4 one if using RJ Bell house
5.fuel pump - External? mine's Bosch (was fitted to a Jag) any high pressur petrol FI pump will prolly do. £15 from a breakers
6.throttle inverter - Custom Off Road (Australia, great service!), RJES or Turbo Thomas
7.the bit that stops your cam belt jumpiing off - Cover? (I noticed yours was cracked on the LHS)
thats all i can think of for now thanks  |
Answers in line
Add in a new Scooby release bearing. _________________ The advice you receive on here is worth the paper it's written on.
Posted: Wed Feb 20, 2008 7:50 pm Post subject: |
the bit that stops cam belt coming off is a giude that didnt come on automatics thanks  _________________ Sutton in Ashfield .Nottinghamshire
Posted: Wed Feb 20, 2008 11:22 pm Post subject: |
Can you post a picture? I've only seen manual engines
Ta _________________ The advice you receive on here is worth the paper it's written on.
Posted: Thu Feb 21, 2008 7:29 pm Post subject: |
Ahh, gotcha.
You'll waste lots of time at a breakers removing that.
Errrm, I'm gonna state the obvious (like what Rich said) Subaru dealer. You'll find some new parts are very reasonably priced! _________________ The advice you receive on here is worth the paper it's written on.
