split_trix Jedi Knight
Posted: Wed Feb 20, 2008 7:08 pm Post subject: subaru wrx 06 engine immobilser |
is it possible to put an 06 wrx engine into a vdub ?
its variable valve timing so will be keeping the ecu but my main concern is the immobiliser is this bypassable ?
chris _________________ 52 vwrx |
doppelganger Jedi Guardian
Posted: Wed Feb 20, 2008 7:59 pm Post subject: Re: subaru wrx 06 engine immobilser |
| split_trix wrote: | is it possible to put an 06 wrx engine into a vdub ?
chris |
why would you want to bypass it ?
just incorporate it  _________________ vwdrc class rep
Posted: Wed Feb 20, 2008 8:00 pm Post subject: |
thats an idea, but what parts would you need for the imoobiliser to work ? wouldnt you needs the car keys ????
Posted: Wed Feb 20, 2008 8:19 pm Post subject: |
| split_trix wrote: | thats an idea, but what parts would you need for the imoobiliser to work ? wouldnt you needs the car keys ????
chris |
you will need the chip anyway what ever you do i think  _________________ vwdrc class rep
Posted: Wed Feb 20, 2008 11:18 pm Post subject: |
chris |
Haven't you posted this on Aussies?
I think the 06's might use the Canbus(?) system which is like an "in car internet" which would make the loom a pig. (I could be wrong, feel free to correct me)
With my Scooby I needed the chip from the key, antenna & immob 'gubbins'. Breakers like to be able to re-sell entire lock sets from the donors but will remove the chip from the key for you _________________ The advice you receive on here is worth the paper it's written on.
Posted: Thu Feb 21, 2008 8:44 am Post subject: |
i did post it on aussie's on ricola's advise ....
cheers for the info..
Posted: Thu Feb 21, 2008 11:13 pm Post subject: |
Ignore my comment, I see RJ's replied to you on VZi
(makes note about 08's not 06's!) _________________ The advice you receive on here is worth the paper it's written on.
