gerrelt Jedi Master
Posted: Mon Dec 10, 2007 2:36 pm Post subject: Using rectangular tubing? |
Hi,
For leading the coolant to the (planned) rad up front, I am contemplating rectangular tubing.
Instead of using 32 mm round tubing I want to use 15 * 60 mm rectangular tubing (if I can find it somewhere). The advantage is a 17 mm more ground clearance, because I want to mount it under the central tunnel of my 1303 beetle.
An extra advantage will be that the rectangular tubing will cool better than the round one, but that's only a marginal advantage.
The problem I see in using it is I would have to weld all the bends, as bending is not possible.
Would a beginner welder, like me, be able to weld a water tight connection?
Would the flow be affected by the rectangular tubing?
Greetings!
Gerrelt. _________________ homepage
VolksRomeo 13033 S 1.4 IE
_________________ |
Posted: Mon Dec 10, 2007 3:13 pm Post subject: |
I dont know the answer but are you really so low that 17mm is going to make a difference? and will it be enough difference to justify a LOT more work?
surely the effort could be put into making a shield for the underslung pipes?
good luck if you go for it! |
gerrelt Jedi Master
Posted: Mon Dec 10, 2007 8:26 pm Post subject: |
No, I am not that low, I like my lowerings functional.
It's 4 cm lowered in the front and about 2 cm lowered in the rear.
I've got 15 cm's of ground clearance:
But this is without the front bumper installed, and with nobody in the car.
I would like to retain a reasonable ground clearance. _________________ homepage
_________________ |
gerrelt Jedi Master
Posted: Fri Dec 14, 2007 12:31 pm Post subject: |
After doing some research on the internet, welding a watertight seam with a flux core mig welder can be tricky. So, indeed, a lot of trouble for 1,5 cm extra groundclearance. I probably will use round tubing, and will rent a tube bender for a day. _________________ homepage
_________________ |
72panelvan Jedi Master
Posted: Sat Dec 15, 2007 11:39 am Post subject: |
| gerrelt wrote: | After doing some research on the internet, welding a watertight seam with a flux core mig welder can be tricky.
pretty much impossible, did a repair on a fuel tank and it was nigh on impossible to get it water tight!
tom |
