pantswagen Padawan
Posted: Tue May 27, 2008 5:25 pm Post subject: is ther an off the shelf mounting to fit type 1 frame horns |
ie I hqave a super beetle - ate model 1303's' rear cradle
-the mounts unbolt
-is ther 'like' just a pair of 90 degrre shaped bits I can buy off the shelf?
direct to the scooby egine mountings
rjes Jedi Guardian
Posted: Tue May 27, 2008 10:33 pm Post subject: |
I assume you mean for a bus box in a Beetle? If so, no, as far as I know, nobody makes such a mount. Doing so is on my to do list, but it's part of a bigger project, and not at the top of the list yet. _________________ Regards,
www.rjes.com |
trev Jedi Master
Ianbott Jedi Knight
MostlyMonki Jedi Master
Posted: Mon Jun 02, 2008 10:57 am Post subject: |
I'm using that ssp kit for my bus box bug... the fits not great though (you get what you pay for), and needs a little fettling with to fit. not a bad starting point though. I'm probably going to fab up tome extra engine mounts as i'm not confident in the strength of it.
I'll see if i can get some pics of my install if you want!? _________________ '72 Ratty Bug - Subaru EJ20 Turbo motor. |
Posted: Mon Jun 02, 2008 11:00 am Post subject: |
forgot to mention, the main pain with this kit added to the rjes bellhousing is that it makes it difficult to move the box forward much, so you end up with it further back than is ideal (i've had to cut sections out of my rear wings, as well as stand the decklid off both top and bottom). _________________ '72 Ratty Bug - Subaru EJ20 Turbo motor. |
