lowlight 185 Padawan
Posted: Sun Jul 06, 2008 11:48 am Post subject: oil pressure switch |
hi folks got my water gauge in and just took alternator off to fit oil pressure switch but it fouls on the alternator is there anywhere else i can put this or have i got to tap the case
thank Simon  _________________ Sutton in Ashfield .Nottinghamshire
home of the robin hoodys |
Posted: Sun Jul 06, 2008 6:04 pm Post subject: |
You can move it to the blanked off plug at the rear of the case if you've got space there _________________ The advice you receive on here is worth the paper it's written on.
doppelganger Jedi Guardian
Posted: Sun Jul 06, 2008 6:27 pm Post subject: |
if it hits the alternator put an elbow union on it and you can cut the alternator bracket till it fits ,i did it about 5yrs ago and the bracket is still ok  _________________ vwdrc class rep
rjes Jedi Guardian
Posted: Mon Jul 07, 2008 4:25 pm Post subject: |
Look on eBay. You can buy replacement plugs for the Subaru oil galleries tapped with various threads to suit your sender. That way you don't need a T piece to fit both the gauge and the switch (unless you have one of the VDO senders which also has a switch built in. _________________ Regards,
www.rjes.com |
