top part, you must replace this!
illzlee
PostPosted: Thu Aug 10, 2006 11:39 am    Post subject: top part, you must replace this! Reply with quote
i've just had my first road test in my van for ages, the best thing i noticed was the improvement in the steering! i've replaced the small shocker on the steering arm (technical i know) with the cheap brazilian model from gsf, such a difference! you need to replace this if you haven't already - the van no longer chooses where it wants to go.........i took my hands off the wheel (safely, in the name of science) and it just went straight! on a bumpy road!
this has been the best improvement i've made, for only £14 and two bolts to fix! do it!
PostPosted: Thu Aug 10, 2006 2:19 pm    Post subject: Reply with quote
That'll be the steering damper Wink
Interesting that, not something I would consider changing might do that once I'm up and running for a bit so I can appreciate the difference. I'm guessing mine might tram line a bit now I have upgraded to 17" wheels so prob worth replacing at that price.
cheers for that
famous phil
PostPosted: Fri Nov 17, 2006 11:46 pm    Post subject: test Reply with quote
Hello simple to check to see if any good or not , get under your van and undo one end , then pull and push a few times should go nice n stiff
maybe the other half might be able to do this better Laugh Out Loud
Covin
PostPosted: Sat Nov 18, 2006 12:09 am    Post subject: Reply with quote
Didn't even need to check mine as it fell off when I removed the beam Laugh Out Loud There was just a rusted lump of it left hanging there Grin
Got a nice new one to go back on though.
Have to say I changed the one on my Covin a few years ago and it made a big improvement to the feel of the steering, especially at speed
DARREN
I LOVE RUST ME
