aussie_b Force Sensitive
Posted: Wed Dec 17, 2008 12:58 pm Post subject: Crankshaft to Crankcase Measurement - 1.9 Water Boxer ??? |
Hi all,
Trying to find out what offset (if any) is between the surface of the crankcase (where the bellhousing bolts to) to the surface of the crankshaft (flywheel side) ?
I've decided to attempt to make an adapter plate to install my diesel PUG engine because can't seem to buy one anywhere...
Any info will be much apreciated.
Cheers
Aussie_B _________________ T25 Hi-Top Camper part way through conversion from 2.8I Capri Engine to 1.9 Citroen - longest conversion in history!!!
Merc 190d running on Veggie Oil - now sold |
andymacdonald30 Initiate Jedi
Posted: Wed Dec 17, 2008 9:56 pm Post subject: Mad angle of the pug motor |
Hi aussi_b
I am not too sure of the angle but here is a pic of mine
I would guess at 35 40 degrees
Andy _________________ 2002 T4 2.5 tdi
1987 T25 1.9 D |
Posted: Sat Dec 20, 2008 3:24 pm Post subject: |
Thanks for the photo, not quite what i was after but it's very hard to describe...
I'm trying to find out how far the surface of the crankshaft (where the flywheel attaches to) from the crankcase - ie where the gearbox bellhouse connects to.
Thanks again.
Brett _________________ T25 Hi-Top Camper part way through conversion from 2.8I Capri Engine to 1.9 Citroen - longest conversion in history!!!
