wiring diagram
andy syncro-nutz
PostPosted: Tue Dec 09, 2008 10:13 pm    Post subject: wiring diagram Reply with quote
Hi All! Having a bit of trouble finding the correct diagram for my EJ22 Loom, Its a 95/96 with three yellow connectors at the ECM 1x26pin, 1x16pin and 1x22pin, Chassis JF1BG7KJ4SG007482
Im fitting it to a T25 2.1 DJ Syncro, Any help finding a diagram would be great! Cheers Andy,
PostPosted: Tue Dec 09, 2008 11:02 pm    Post subject: Reply with quote
I have pre MY97, not specific to 95-96.
Can ya handle a 3.3M PDF file via e-mail?
andy syncro-nutz
PostPosted: Wed Dec 10, 2008 12:32 pm    Post subject: Reply with quote
That would be great if it has the three yellow plug ecm connector in it rather than the single blue ecm connector cheers Andy,
PostPosted: Wed Dec 10, 2008 3:24 pm    Post subject: Reply with quote
Damn, I'd cancelled that post after I'd noticed the PDF is for a turbo one.
I do however have a 97 Turbo one that was almost my 97/98 NA EJ20 one, once you'd removed the turbo bits.
(I found it about a year after I'd done my convo - I buzzed out the whole ECU loom!)
I can scan and e-mail you that tonight. It'll probably get you in the ballpark.
Did you get the whole car?
I still can't find a proper diagram for my 97/98.
andy syncro-nutz
PostPosted: Wed Dec 10, 2008 10:10 pm    Post subject: Reply with quote
Has anyone seen this ECM i have with the three yellow connectors?
http://www.flickr.com/photos/14602120@N03/3090335849/
http://www.flickr.com/photos/14602120@N03/3090595319/in/photostream/
PostPosted: Thu Dec 11, 2008 12:23 am    Post subject: Reply with quote
Will check my ECU tomorrow. Mine only has 3 yellow conns, like yours
Did you get my e-mail?
andy syncro-nutz
PostPosted: Thu Dec 11, 2008 1:53 am    Post subject: Reply with quote
Yeah! That looks just about right with the yellow plugs! Happy I just cant read the colour codes and pin numbers
PostPosted: Thu Dec 11, 2008 4:43 pm    Post subject: Reply with quote
Zoom in! I can read them. Use paint shop pro or similar
Don't go by colour codes.
I'd seriously "buzz out" to be sure unless you do find a pukka wiring diagram
andy syncro-nutz
PostPosted: Thu Dec 11, 2008 8:23 pm    Post subject: Reply with quote
Buzz out? Im almost ready to fire it up on the bench, I havent wrapped the loom yet till im sure its gonna work ok!
PostPosted: Sat Dec 13, 2008 12:09 pm    Post subject: Reply with quote
Sorry, "Buzz out" = use a multimeter to test the wiring diagram against what you have.
andy syncro-nutz
PostPosted: Mon Jan 12, 2009 3:31 pm    Post subject: Reply with quote
Seems the diagrams for these cars cause quite a problem even in the states & Canada too! My local (40mile away) subaru dealer scratched his head and said Subaru might be able to help!
