pantswagen Padawan
Posted: Sat Jan 31, 2009 7:36 pm Post subject: custom steel hubs 68 bay or split for 996 porsche brakes |
et 55 7j wheels only
en24t high grade steel hubs
studs nuts disc screws bearings caps seals
take a 996 disc
£450 a pair
titanium add £300
adaptors for 68 bay and split spindles - billet for radial 996 calipers £300 pair
come with m10 1.5 din 912 socket caps screws - grade 12.9 -
adaptor is recessed into spindle face
discis recessed into hub
NOOTE - ONLY SUITABLE FOR 7J ET55 LATE MODEL PORKER WHEELS
AS IT WILL THEN RUN THE TYRES CENTRE ON THE STOCK TYPE 2 CENTRE
PLUS POST
oh ps studs are pressed in so are the bearings
-you will need to run a tap through your spindles to clean the crud out
-note you can now get 185 35 17 tyres
-nankangs
oh the caps are used 944 |
