BlackCosmos Padawan
Posted: Fri Jun 05, 2009 8:19 am Post subject: SUBARU SUMPS.. |
| what shortened subaru sumps would you recommend for a wrx installed in a t25 using an rjes kit? are there any uk suppliers? would prefer to keep the oil capacity as high as poss..thanks.. |
sven Jedi Guardian
Posted: Fri Jun 05, 2009 8:29 am Post subject: |
Rework your own.
Look here.
The drip leek was around the oil stick. The tube for the stick is soldered and it interferes with the weld seem. |
BlackCosmos Padawan
Posted: Fri Jun 05, 2009 8:38 am Post subject: |
| would rather buy it done!! dont fancy chancing my own..have had a close call,managed to wack something laying on the road..bent and cracked it.. |
MostlyMonki Jedi Master
Posted: Fri Jun 05, 2009 9:21 am Post subject: |
think i read on the rjes website that aftermarket sumps wont fit if your using hes engine support bar. might be worth double checking with richard though... _________________ '72 Ratty Bug - Subaru EJ20 Turbo motor. |
BlackCosmos Padawan
Posted: Fri Jun 05, 2009 2:27 pm Post subject: |
| that wont be any good as used rjes kit to fit..may chop it down and add oil cooler and remote filter kit..has anyone used a bug@5speed or similar? |
Posted: Sun Jun 07, 2009 11:58 pm Post subject: |
The German made, 2 piece aluminium sump won't fit with my engine mounts, or any other mounts which use the standard Subaru engine mounts in their original locations. It ws designed for use in Beetles, with the engines cantilevered off the gearbox. _________________ Regards,
doppelganger Jedi Guardian
Posted: Mon Jun 08, 2009 6:44 pm Post subject: |
| BlackCosmos wrote: | | that wont be any good as used rjes kit to fit..may chop it down and add oil cooler and remote filter kit..has anyone used a bug@5speed or similar? |
im using a rjes bellhousing ,bug@5speed sump and remote cooler with my turbo caravelle _________________ vwdrc class rep
Posted: Mon Jun 08, 2009 10:38 pm Post subject: |
| doppelganger wrote: | | BlackCosmos wrote: | | that wont be any good as used rjes kit to fit..may chop it down and add oil cooler and remote filter kit..has anyone used a bug@5speed or similar? |
im using a rjes bellhousing ,bug@5speed sump and remote cooler with my turbo caravelle |
what are you doing about engine support mate? I see tsr do a seperate engine brace bar for use with lowered sumps... was thinking about maybe mixing up some parts with my conversion. _________________ '72 Ratty Bug - Subaru EJ20 Turbo motor. |
Posted: Mon Jun 08, 2009 10:40 pm Post subject: |
| MostlyMonki wrote: | | doppelganger wrote: | | BlackCosmos wrote: | | that wont be any good as used rjes kit to fit..may chop it down and add oil cooler and remote filter kit..has anyone used a bug@5speed or similar? |
what are you doing about engine support mate? I see tsr do a seperate engine brace bar for use with lowered sumps... was thinking about maybe mixing up some parts with my conversion. |
i just made my own  _________________ vwdrc class rep
Posted: Mon Jun 08, 2009 10:42 pm Post subject: |
pics!!  _________________ '72 Ratty Bug - Subaru EJ20 Turbo motor. |
BlackCosmos Padawan
Posted: Wed Jun 10, 2009 11:46 am Post subject: |
| having the sump shortened by mark at A2B in newmarket and gonna add a remote oil cooler.. |
