split_trix Jedi Knight
Posted: Fri Jul 27, 2007 6:16 pm Post subject: 944 Alli Trailing arms prob |
Hi, i've got a pair of alloy arms but the bottom shock mount is missing, what thread and size are these ? I assume something like M16 and might be high tensile steel... but not sure...
If they are M16 then would it be possible to enlarge the top shock mount hole on the shock tower to the larger size ?
chris _________________ 52 vwrx |
trev Jedi Master
Posted: Fri Aug 17, 2007 12:43 pm Post subject: |
| on my early aluminium 944 arms it appears to use a bolt to hold the shock on, and not a stud and nut, there appears to be a threaded insert deep inside the arm. From memory the thread is M16 but it's been a while since I looked... |
Posted: Fri Sep 28, 2007 9:16 pm Post subject: |
I found the thread is M16X1.5, allfix gave me M16X2 and i partially mashed up the threaded insert (helicoil)... so had to get an M16X1.5 tap (unobtainable unless in a complete set)
1303Steve Jedi Knight
Posted: Fri Aug 07, 2009 2:04 pm Post subject: |
I have the Porsche parts program PET5 on my PC. It says that the bolt is M14 x 1.5 x 85.
Steve _________________ STI powered 1303 now running
G50 box, Boxster/944 brakes, Adaptronic 1280E ecu, PWR intercooler etc |
