throttle body coolant hoses
Joel
PostPosted: Sun Sep 06, 2009 12:44 pm    Post subject: throttle body coolant hoses Reply with quote
hey all
now that ive relocated my throttle body the stock 8MMish? coolant hoses that come from the IACV arent long enough
has anyone ever used fuel hose for these?
seems to be identical hose im just wondering about the temp rating?
anyway will speak to a rad shop this week but just wanna hear other peoples ideas as i know a few on here have relocated their TB
gerrelt
PostPosted: Sun Sep 06, 2009 2:03 pm    Post subject: Reply with quote
I've used 8 mm fuel hose for exactly the same purpose. But then on my Alfa engine.. Happy
It's doing fine, no problems. About 3 years now and more then 5000 kilometers.
They don't dry out, and they don't leak.
homepage
VolksRomeo 13033 S 1.4 IE
PostPosted: Sun Sep 06, 2009 10:06 pm    Post subject: Reply with quote
I used 8mm (? as it's such a long time ago) Samco. Had no probs
PostPosted: Tue Sep 08, 2009 7:55 am    Post subject: Reply with quote
How cold is it near you?
I've read before ( unfortunetly I have no proof of my readings ) that the water travelling through the throttle body is only to warm it up and to prevent it from icing up in colder climates. Like those silly blankets you can buy for an lawn mower engine that wrap around the inlet manifold.
So... If the ambient temperature near you isn't that cold then in theory you won't need to keep your throttle body warmed up which in turn warms up your inlet air.
On the post I read the peope where skipping out the the throttle body and going straight to the other bit ( I think it's the idle stabilisation valve).
I'm open to being corrected on this on especially until I can come up with some proof. However if you relocated you throttle body it keep your engine bay alittle tidyer by not having to run extra pipe work around.
I'm pretty sure that in the article I mention they where using standard fuel pipe to by pass the throttle body.
Joel
PostPosted: Tue Sep 08, 2009 11:26 am    Post subject: Reply with quote
thanks all
i figured it was just for heating purposes
its not a cold area here on the australian east coast
lowest winter temps are only around 4C/40F
but the pipework is all there for it, just need some longer hoses
i wanna replace the existing ones anyway as theyre original and well over due for changing
PostPosted: Wed Sep 09, 2009 12:21 am    Post subject: Reply with quote
The coolant fittings are just to preheat the throttle body to prevent icing when it's cold and damp. Fuel hose will be fine.
PostPosted: Wed Sep 09, 2009 8:09 am    Post subject: Reply with quote
Google is amazing:
http://www.rexnet.com.au/forum/index.php?showtopic=43496
