door gaps on 1971 bay
Superleggo
PostPosted: Fri Dec 11, 2009 12:02 am    Post subject: door gaps on 1971 bay Reply with quote
ok have I lashed this up? I have just reskinned the doors and fitted them to the camper and they fit well with even door gaps. I have now ust replaced the front wheel arch which seems to fit the door well at the higher section on the door bottom but I have got a 12mm gap at the lower edge at the lower door shut.
As both panels are new, is it meant to be like this or have I lashed it up as it seems wrong? I have fitted the other side and again it seems ok in all areas except the lower edge again. On this side I have not replaced the front wheel arch yet.
Is this right?
VW Camper 1971
VW Passat 2006
Lotus Elan +2 1968
Mini Moke 1974
Land Rover Series 2a 1967
DB5 replica Work in progress
Another day another car!
andysamba
PostPosted: Fri Dec 11, 2009 1:14 am    Post subject: Reply with quote
ive had same problem with my bay aswell.
because i changed the arches both sides i left them with the big gaps at bottom.
ive seen loads around with big gaps at the bottom-seems to be the in thing to have at the moment!.
woudnt worry to much. Grin
PostPosted: Fri Dec 11, 2009 10:07 pm    Post subject: Reply with quote
not your fault the pattern parts are shite. if you look in my build thread you will see I had to cut and shut my pattern arches to get them to fit cos i couldnt live with massive door gaps i could get my fingers in!!!
basically cut it into 4 pieces and aligned with door and welded back together again. Not ideal but neccesary
Superleggo
PostPosted: Sat Dec 12, 2009 9:02 am    Post subject: Reply with quote
Thanks for the vote of confidence I thought I was loosing the plot. I think you are right Rich time fot the 9" grinder and take a slice out as I know it will annoy me.
VW Camper 1971
VW Passat 2006
Lotus Elan +2 1968
Mini Moke 1974
Superleggo
PostPosted: Sat Dec 12, 2009 9:27 pm    Post subject: Much better Reply with quote
Rich
You are right it is well worth the effort and not too difficult.
sorted the LHS will do the other tomorrow.
VW Camper 1971
VW Passat 2006
Lotus Elan +2 1968
Mini Moke 1974
hansend23
PostPosted: Sun Dec 13, 2009 5:27 am    Post subject: Reply with quote
Happy nice!
just do it!
PostPosted: Sun Dec 13, 2009 11:45 am    Post subject: Reply with quote
had to do same with my split os arch fitted like original ns arch i could get my fingers in to the cab at the bottom edge without opening the door Eeeek so i cut about 10-15mm out of the arch in the middle and it fitted ace then Grin
