what gearbox do most people use
spellbound
PostPosted: Tue Dec 15, 2009 8:33 pm    Post subject: what gearbox do most people use Reply with quote
in their BUG's?
ive heard of the 6 rib one but what other alternatives are there?
im gonna be using a turbo scooby lump.
cheers
Mario Grin
Just smile n sod em all
hansend23
PostPosted: Tue Dec 15, 2009 8:57 pm    Post subject: Reply with quote
im using the stock one,been through one already
so ive got a 6 rib for it.
ill wait till my lift is setup Happy
just do it!
PostPosted: Tue Dec 15, 2009 9:47 pm    Post subject: Reply with quote
From my experience it depends on how much work you are prepared for and how deep your pocket is.
As an alternative to the Vw bus box's you can also use Porsche units. Companies like bug@5spd make it very easy to fit a 901 and some bits for a 915. You also have the G50 which has been used in the past but I wouldn't take any of them on with the dillusion that's it's a weekend job.
A very nice easy solution is to get a built type one box if you want an easy bolt on solution.
Oh let's not forget about the quaiffe box's, I dunno what they are like but I would expect it to be magical what with the costs of one.
Joel
PostPosted: Wed Dec 16, 2009 11:40 am    Post subject: Reply with quote
a few guys round here have used stock boxes
the last if ur gentle with them
but most of them break 3rd gear
a 6rib or any bus box for that matter in stock form has ratios all wrong for a bug unless u have 30" mud tires on the back
they can be re-ratiod though
MostlyMonki
PostPosted: Fri Dec 18, 2009 9:10 am    Post subject: Reply with quote
doppleganger on here runs a stock 091 bus box in his drag car, which i believe tops out in the mid-high 130mph range in 4th... I'm guessing hes running about 26" tyres (Im sure I'll be told otherwise in a minute). so that wouldnt be totally unusable in a bug.
I'm running an 091 in my bug, but had all custom ratios set up when i had it built.
its far from easy/cheap to put a bus box in a bug though, if you want to actually run the shift rod in the tunnel then you'll need to change the intermediate housing and nosecone to one that berg make. thats a £500 job in itself. the other option is to run the shift rod above the tunnel like I've done - but then youll nbeed to fab up a box for the gearstick to sit on.
'72 Ratty Bug - Subaru EJ20 Turbo motor.
STIDUB
PostPosted: Fri Dec 18, 2009 5:23 pm    Post subject: Reply with quote
or do something like mine....
mind you it was anything but cheap, will do what i want it to just fine though:)
Go fast 1302 brought 2 u by
VVDS-resto parts
VForce-Suspension
Craig Torrens-Kafer bars
Glenn Torrens-Brakes
CustomVeeDub-Rear adjuster& stuff
L&D - 091-bug intermediate housing
RJES - EJ2*-091 Bellhousing
...HOPE THIS WORKS!
hansend23
PostPosted: Fri Dec 18, 2009 10:35 pm    Post subject: Reply with quote
hmm,i guess i may just have a good bug box built.
just do it!
doppelganger
PostPosted: Mon Dec 21, 2009 4:54 pm    Post subject: Reply with quote
yes i did use a stock box for 2 yrs with 26" tyres then i broke it and had a box built by bears Grin
vwdrc class rep
ttriebler
PostPosted: Sun Jan 03, 2010 9:13 am    Post subject: Reply with quote
2000 Subaru 8 bolt 5 speed. 4WD.
Reversed gears for Subaru Transmissions
Fit a 5 apeed to your rear engined car
www.subarugears.com
