Posted: Mon Feb 06, 2006 4:14 pm Post subject: cooling idea for a bay window? what about this? |
following a thread on another forum I have been thinking about cooling my bus using downward airflow ratherr than pushing the hot air up through the rad. Ive drawn this rubbish drawing showing the rough chassis layout and position of the rad etc the chassis rails are closed in with the front cross member halfed in height and a big front scoop. Under the side pans there are additional spring loaded or poss manual operated adjustable extra air dusts which ram the air into the central box at speed when the engine is under more strain and potential air flow is greater. The only outlet for all this air is through the flat mounted van radiator. This will have twin 10 inch fans mounted underneath as a precaustion and be shrouded for more efficiency.
Let me know what you think - am I working against the laws of physics or is this feasible set up?
Advantages I see are easy exhaust of hot air out under van, convenient loacation of the rad, use of more than usual amount of ducts (*scope for more if required), potential for massive airflow through the rad.
anyway here it is......(sorry about poor drawing)
Posted: Mon Feb 06, 2006 4:31 pm Post subject: |
Wouldn't having twin mounted + shrouded fans effect the flow drastically through the rad !
Also at the kind of speeds your bus is gonna be capable of won't this unsettle the bus causing it to lift ? I guess it won't do your mpg any favours either.
That said sounds brilliant :P
Not being negative just wondering if any of my points are valid really. _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
2013 Scirocco TDI GT |
Posted: Mon Feb 06, 2006 4:37 pm Post subject: |
| nope it wont unsettle the handling as you are only playing with air thats under there already - as for the shroud - I wondered about this as you have a point - you would think its a restiction but conventional wisdom says that shrods are good and the rad i have already has one fitted. It will also be handy for deflecting stones etc - I think its also supposed to make sure fans draw through all across the rad rather than justi n one place. |
Posted: Mon Feb 06, 2006 4:50 pm Post subject: |
Surely you'll want some sort of mesh in front of the scoop to deflect any stones getting in there ! otherwise you could end up with quite a collection of hardcore in there.
Would it be more beneficial to slant the rad down at the front a bit to get the air flowing a bit more freely in the right direction. _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
Posted: Mon Feb 06, 2006 5:05 pm Post subject: |
there would be a mesh - but thats another advantage - if you destroy the scoop its far from the rad so no worries there!!
as its relying on pressure to push air through slanting rad would have no effect except to lessen ground clearnace. |
Posted: Tue Feb 07, 2006 10:30 am Post subject: |
heres one with airflow on it.........realistic or not?
GeorgeL Wannabe
Posted: Wed Feb 08, 2006 5:13 am Post subject: |
| richbaker78 wrote: | heres one with airflow on it.........realistic or not?
I think that the side scoops are not really needed. You'd have problems getting the air through the frame rails anyway!
Angling the radiator isn't really needed, since you are creating a pressurized plenum above the radiator by boxing in the frame. The front scoop should be sufficient.
I'm working on a very similar idea (planning, no hardware until this summer) for my '71 bay. I intend to be as generous as possible with the size of the radiator to allow it to function without excessive ram airflow.
One advantage of the blow-down design is that you don't move a lot of hot air right next to the floor of the bus. This is a major concern in hot climates!
George |
Posted: Wed Feb 08, 2006 9:03 am Post subject: |
I was thinking the side scoops could be optional really but theres a gap above the chassis rail on mine if reqd. -
the reason I added them was I wonder how much air does flow under the van (mines lowered) the main issue being that the front beam cross bars and the servo all acto to block some of the airflow. THis may reduce the ram air effect.
My other concern is your supposed to blow to a low pressure area - the rad wont be low pressure if mounted like this will it?
another bonus of this design though is that you can easily add more rads if cooling is insufficient.
Im using a VW transporter (t4 model) rad hopefully that should be big enough - keep us posted on your progress it sounds very interesting. |
Cleverchap Jedi Master
Joined: 08 Feb 2006 Posts: 356 Location: Middle of the Midlands
Posted: Wed Feb 08, 2006 2:05 pm Post subject: |
Looking at your design I think you might be correct about this fear. The air pressure below the rad might be equal to that above it, causing no air flow over the radiator.
You may have to try the concept whilst closely monitoring coolant temp.
I will be running a flat rad deisgn with twin fans mounted above the rad drawing cold air through when the vehicle is at rest and operated from a stat.
Whilst in normal driving I hope the venturi effect will draw cold air down through the rad taking heat with it.
When my system is up and running I'll let you know the results :smt002 |
Posted: Wed Feb 08, 2006 3:30 pm Post subject: |
it seems im gradually arriving at the fact that I will have to suck it and see!!
i guess if I maximize the size of the front dam and move the rad closer to it then the potnetial for the venturi effect with this set up is greater (ie creating lowvpressure under the rad and high above.
Welcome to the board BTW  |
