beetleseb Jedi Knight
Posted: Thu Feb 23, 2006 1:18 pm Post subject: More bay window cooling questions and ideas |
Hi guys
Looking at putting a subaru 2.0 or 2.2 in my Bus (not going the turbo route). Having only ever played with lawn mower toys before, I am a bit confused when it comes to rad sizes.
The subaru 2.2 should have a 670x390x17mm rad fitted as standard and some came with smaller rads (670x358x17mm).
Would a thicker unit say a 600x380x26 (ford mondao) do the job if mounted under the car. I use this as an example cos there is a guy on ebay that sells them in aluminium for about £60 inc postage! The maths says that its surface area is a touch smaller but what compensation will the thicker alluminium core give me?
I plan to make a stainless duct to scoop air up and force it down through the rad possably with more ducting to create a venturi effect. As this rough sketch shows.
This should both push air in and suck it out giving great cooling.
So whatdya all think - will it work
Seb _________________ Everybody is someone else's weirdo |
steamo Jedi Knight
Posted: Thu Feb 23, 2006 1:53 pm Post subject: |
My dad's in the process of rebuilding his morgan for the third time with a third more powerful still engine. Its gone from ford 1600CVH to RS2000 engine to RS2000 engine with scorpio 2300 block now its having a 3000 V6 from an X type Jag.
With the 2300 engine despite fitting a bigger capacity rad, he always had cooling probs. The rad in the morgan is tipped back slightly the fins are not parrallel to the airflow, he was told earlier in the week that this can have a quite a dramatic effect on the cooling.
I think that this is an important consideration in designs like these.
Hows he overcome it?? - fitted a masive rad from a V8!!
Hope this helps. |
Posted: Thu Feb 23, 2006 2:17 pm Post subject: |
i would get too hung up on rad sizes /calculations etc- mainly because subaru would have worked out the sizes based on the airflow achieved by mounting in front which is significantly more than underneath in the way you have shown. Conventional wisdom seems to say that the bigger the better. A guy in Oz is using a daewoo leganza rad, above bus a legacy rad and Jp on here a mondeo rad. As i sadi before im going with a t4 van rad. So really rad size etc is not too critical as long as its big - managing the air is the key.
What people never say in their wirte ups is how much and how long their fans are on - fine if the coolings good but if the fans are on all the time then I think its not a good design i may be wrong but im suspicius that a lot of those people running belly mounted rads rely on fans to suck air up thru the rad.
The way you have designed it is very similar to my set up and relies on more logical airflow principles (IMO) but if your doing that why have a sloped rad? surely if the rad is enclosed the high pressure created means the only way out is down thru the rad into the relatively low pressure in the lee of the scoop- thus flat mount the rad will be just as good and will avoid the airlocking and efficiency issues associated with sloping - it will also mean a greater choice in rads as the in/out pipe location wont be so important. on the whole I like it but I wouldnt slope the rad.
Rich |
Posted: Thu Feb 23, 2006 2:42 pm Post subject: |
The sloped rad is all about trying to get airflow through the vents. As steamo says if the fins are parrellal to the airflow its gotta help. The easier the air gets through the more airflow you will achieve. Blocking the rad in will force air through it, but simple physics suggest that it will be harder for the air resulting in less air flow.
That being said I did some searching and those Type 4 rads are big arn't they. I've emailed the ebay guy to see if he can get them in alloy and a price.
I wonder if a really thick 3 core rad, the same width as the space inbetween the chassis rails but short enough to sit upright would work..... Or there is that usefull space where the fuel tank should be.
Airflow has to be the way forward as normal car designs would suggest. Fans are for traffic jams. _________________ Everybody is someone else's weirdo |
Posted: Thu Feb 23, 2006 2:56 pm Post subject: Thick Rad |
I have a thick rad on my bus at the mo (see rad archive section) and it struggles especially on hot days...I also think the fans have little/no effect on drawing air through it... hoping Mondeo rad is the answer as it was cheap  _________________ 1971 Devon Bay with 1800 Ford Turbo Diesel Engine (wip)
Posted: Thu Feb 23, 2006 3:52 pm Post subject: |
t4 rads available from GSF for about £60 i think - conveniently give you measurements too and the pipes are both in one end.
Mine cost £30 inc fans from scrappy.
back to the slope - if thats the case why bother with a scoop at all? surely your better sloping the rad and using that as a scoop.
im not sure I understand this......
| Quote: | | The easier the air gets through the more airflow you will achieve. Blocking the rad in will force air through it, but simple physics suggest that it will be harder for the air resulting in less air flow. |
I think your assuming the air is flowing in nice laminar flow? if so what you say makes sense - unfortunatly though its turbulant by this point under your bus so you cant rely on flow alone.
The main factor for achieving efficient flow thru the rad is creating a pressure difference either side high/low. this means you can flow 'more' air thru it than if you have equal pressure either side and blowing air through it. the scoop will act to pressurise the air in the box made by chassi rails if its closed off (high pressure) whilst also creating a venturi effect under the rad (low pressure) the air will have no choice but to flow high to low.
One good thing about the sloped design though is the increased venturi effect caused by the rad creating a nice low pressure underneath.
something else im doing to increase my scoop mouth area is losing the front cross member and sliming it by a few inches this maybe worth considering whichever way you go. THeres a rad set up like yours being run in Oz - see the pictures section |
Posted: Thu Feb 23, 2006 4:27 pm Post subject: |
You're right I am mainly thinking air flow.
I wasn't thinking of turbulance you're right, I'll look at creating air pressure differences as well as just airflow. Back to the drawing board
www.nissens.dk is a good site for dimensions and schematics for rads, you'll have to log on though. I was supprised at the size of the rad core in the TRANSPORTER T4 (90-) 2.8 i VR6 is a shocking 720 x 414 x 32 and as you say the pipes are in a usefull place.
I still like the idea of sloping the rad with the pipes at the top, but I prefure the idea of the ducting hitting the speedbumps. I also like the idea of the rear ducting adding the venturi effect. By combining the two I'll hopefully make the best of the bad airflow and create pressure differences
Are you expecting any problems with trapped air etc. I've been told that this can be a real headache and filling the system can be a nightmare.
I must say that a rad at the back is getting tempting!
Cheers for the pointers
Posted: Thu Feb 23, 2006 5:04 pm Post subject: |
ill have al ook at that site - cheers.
Dont get me wrong im not saying your set up wont work - I think it has the makings of a good idea.
as for trapped air well thats a whole different argument -im currently having dillemas about which way to go on this basically the way I understand there are two types of system - one is the std system like this which i was gona go with which bleeds air from the system by t ing the header tank into the main cooling system - im still eering towards this as I already have the bits - T25 bottles are nice and big btw
but then I found out about a flow thru system which is tempting - where the entire flow from the engine coolant outlet goes through the header tank before going to the radiator, apparently the advantage is that air is left in the header as it flows through the aparently downside is that the tank has to be bigger to stop air going back into the system.
so there you go - another thing for you to ponder!!
tip of the day with cooling systems tho is getting the header tank as high as poss. |
doppelganger Jedi Guardian
Posted: Thu Feb 23, 2006 8:33 pm Post subject: |
Hi Ian
I've chatted to Andy at TSR (lovely guy) about his custom rads for the back end but he hasn't been able to supply any photo's. PC problems.
Andy suggested that by cutting a space behind the no plate and stepping it out an inch I can create enough flow, should make the pipework a doddle too.
Do you use any ducting etc or just let the air do its thing? Any idea what that rad in the photo is off (doesnt look aluminium) or is it best to get one off Andy. They are not a bad price for a custom 3 core rad and it means I could go turbo one day.......
Posted: Thu Feb 23, 2006 8:41 pm Post subject: |
| beetleseb wrote: | Hi Ian
Seb |
the one in the pics is one of the custom ones,no ducting and i`ll take a pic of one thats there with number plate stood off on saturday,or any other pics if there is a van etc available(let me know) _________________ vwdrc class rep
Posted: Thu Feb 23, 2006 8:54 pm Post subject: |
As many pics as poss without being cheeky would be great.
Does he use ducting on them now or is there enough airflow back there?
A rad at the back is getting more and more tempting....... now where did I put that cheque book
