Posted: Mon Jul 17, 2006 3:24 pm Post subject: Temp sender & gauges |
I'm trying to find a suitable sender and compatable gauge for the Scooby. The standard sender is 1/8 BSPT. What aftermarket stuff is available in that fitting?
If not I can tap a different thread but would prefer not to go this route.
Apart from a Scooby gauge what would be compatible with the Scooby sensor?
Part numbers & suppliers info would be great
Does anyone have anything suitable?
TIA
D'oh. Must use google more often
Part No 310-010-002K for the VDO 40-120°C gauge. £33.96 |
Cleverchap Jedi Master
Posted: Mon Jul 17, 2006 9:11 pm Post subject: |
I've got an Autometer guage and sender on my EJ22 motor.
Can get part numbers tomorrow for you |
Posted: Mon Jul 17, 2006 10:53 pm Post subject: |
Yes please.
Do I need to drill and tap the Scooby manifold or is it 1/8 BSP T? |
Posted: Tue Jul 18, 2006 8:23 am Post subject: |
| you can get adaptors from hose suppliers like bristol hose, etc to convert one thread to another - I think autometer guages come with some adaptors too but exactly what sizes I dont know. |
Alex (FTS) Jedi Guardian
Posted: Tue Jul 18, 2006 12:40 pm Post subject: Demond tweeks |
Phone up some were like demon tweeks they have all the gauges and sensors you can imagine. Just tell em you need the sensor for you scuby engine. Thats what I did for my ford engine-they were very helpfully and told me all the parts I needed.
Good luck _________________ www.faltownskateboards.com |
Posted: Tue Jul 18, 2006 2:28 pm Post subject: |
I read on one site (weidefamily.net ?) that the VDO 40-120 is compatible with the Scooby sender.
I have ordered the gauge from JustKampers and will let you know. I was questioned why I needed one for an lawn mower '78 bay
I shall keep you posted. |
stcos85 Force Sensitive
Joined: 24 May 2006 Posts: 16 Location: rayleigh, essex
Posted: Thu Aug 17, 2006 10:20 pm Post subject: |
elusivestranger,
Did the sender work as I have a VDO gauge. As a temporary measure I fitted a ford one(i think) which seemed to have the same thread but am not sure it gives the correct reading.
I will have to check at what temp the fans kick in and compare this to the gauge.
steve |
Posted: Thu Aug 17, 2006 11:26 pm Post subject: |
I tried it in boiling water and it reads approx 92°. At least I know how wrong it is on the bench.
Haven't actually fired it up yet but that's coming soon. |
Posted: Fri Aug 18, 2006 11:28 am Post subject: |
VW Golfs use VDO senders- have a look down the scrap yard and you should be able to find one. You can buy adaptors from demond tweeks to adapt the thred but I have a sneeky suspision they are the same on the golf and the escort.
Its definatly worth having matching senders and gauges espeshaly on your temp gauge. I ran mine for about 2 years with odd gauge and sensor and changing it to a matching per was the best thing I ever did-I got alot better acuracy which ment I could prevent any over heating issues well in advance to them happening on long journeys. I fitted an oil temperature gauge too, which also helps alot to take make informed decisions when the engine is getting hot. _________________ www.faltownskateboards.com |
Posted: Sat Aug 19, 2006 8:55 pm Post subject: |
sorry for jumping in on this thread.
alex,
for your oil temp did your use a sender in the drain plug.
Back to the water temp. In my ignorance and with my rad at the back would it be fair to say that once the fan comes it will stay on for the duration of the journey. May seem a really stupid question to some but I have to ask and if so what temp should it settle at. |
Covin Darth Admin
Posted: Sat Aug 19, 2006 10:27 pm Post subject: |
Your fan should switch on and off depending on engine Temperature.
Usually your fan will never come on while your on the move if you have good airflow over the radiator but once in traffic etc the fan should then cycle on and off to aid airflow while your not moving or driving very slow. _________________ DARREN
I LOVE RUST ME
Posted: Sun Aug 20, 2006 4:07 pm Post subject: |
| I understand the theory but are you saying even in the back I should expect decent air flow without the fans working. If thats the case then I need to somehow feed some air into the engine bay as the fans come on as soon as the temp gets up to about 90 degrees. Any ideas? |
