sven Jedi Guardian
Posted: Mon Nov 15, 2010 10:44 pm Post subject: Hardcore inner sills? The solution is... |
50x50 mm square tubing. Two on top of each other!
I need to replace a peace of the innersill and one of the outriggers to pass the yearly MOT. The sills are darn expensive but after some measuring I found out that all pieces that needs replacement are 50x50 or 50x100. My garage pal looked up and said: "hey, we've got about a 100 metres tubing laying around...". They are 2 mm in thickness, so I believe my inner sills are going nasty.
That MOT technician can bang his hammer until he turns blue.  |
Inane Cathode Jedi Knight
Posted: Tue Nov 16, 2010 7:11 am Post subject: |
| Wait a minute, are you saying when they do inspections over there they hit your car with a hammer? |
Posted: Tue Nov 16, 2010 8:16 am Post subject: |
In the UK (not speaking for Sven here) they can hit it with a plastic coated "toffee hammer"
Sounds like a good idea Sven. _________________ The advice you receive on here is worth the paper it's written on.
Posted: Tue Nov 16, 2010 8:19 am Post subject: |
they do in england it's called the corrosion assesment tool "cat hammer" and it is used to test the structural integrity of the vehicle _________________ 1964 rat 13 window deluxe 1Z tdi,
sven Jedi Guardian
Posted: Tue Nov 16, 2010 9:52 am Post subject: |
Plastic hammer?! No way, they use the aggressive sharp edged one of a kind. If they make a hole, you're the one who's supposed to fix it. On top of that, if you don't do it within four weeks and pass a new MOT, your car is not road legal...
A friend of mine replaced the sills with 3 mm stainless and added a layer of paint on top. The technician thought he found a "cover up" for bad sills, so he picked up the hammer with a smile and banged hard. That car rang like a church bell. He passed.  |
Posted: Tue Nov 16, 2010 2:32 pm Post subject: |
Someone over here hits my car with a hammer it'll end up where the sun don't shine.
*spits in a spittoon* |
Griff71 Jedi Knight
Posted: Fri Nov 19, 2010 1:42 pm Post subject: |
My MOT guy uses a screw driver! If he finds any corrosion he tells me you got some welding to do there Mr Griffin. Then he gives me my MOT certificate and allows me 12 months to fix it!! I don't reckon he would let it go through 2 years running though!
Anyway i have been going there 13 years now and he knows if i have missed something and he points it out it will be fixed immediately.
Griff _________________ 89 Crew Cab (Subaru 2.5na)
71 Drag Bug (1955cc dual 40s)
65 Ragtop Bug (low & stock) |
Posted: Fri Nov 19, 2010 7:06 pm Post subject: |
| Griff71 wrote: | My MOT guy uses a screw driver! If he finds any corrosion he tells me you got some welding to do there Mr Griffin. Then he gives me my MOT certificate and allows me 12 months to fix it!! I don't reckon he would let it go through 2 years running though!
Griff |
use of anything other than the cat hammer is against vosa rules and could cost the tester his/her licence! _________________ 1964 rat 13 window deluxe 1Z tdi,
sven Jedi Guardian
Posted: Fri Nov 19, 2010 8:18 pm Post subject: |
Well, if the screwdriver was around half a kilo, you would be close to my MOT tools...
Posted: Sat Nov 20, 2010 12:33 am Post subject: |
| 13 window deluxe wrote: |
use of anything other than the cat hammer is against vosa rules and could cost the tester his/her licence! |
TBF I'd rather he smacked a hole in a very weak point and said fix it.
My tester's been great and used disgression where he's deemed it necessary.
I'll still never forgive him for snapping the handbrake cable on my bug & failing it. I called a fecking ape, he laughed. Never realised there were so many hill starts on the way home  _________________ The advice you receive on here is worth the paper it's written on.
sven Jedi Guardian
Posted: Wed Nov 24, 2010 7:17 am Post subject: |
Square tubes and 1 mm galvanized sheets are good stuff.
