graham-e Padawan
Joined: 30 Aug 2008 Posts: 78 Location: Lake District
Posted: Thu Jul 15, 2010 11:16 am Post subject: Speedometer... |
Just been thinking about what I'm going to do with my dashboard. I wondered if the RJES speed sensor could also be used to drive a digital speedo?
Cheers, Graham. |
Posted: Thu Jul 15, 2010 3:10 pm Post subject: |
Yes, it's what Brantz make them for!
4 pulse/wheel rev at 5V.
Put that pulse into a box containing "Electrickery(TM)" and you can get a speed reading.
After all Speed is proportional to wheel RPM
Even better, get a car based PC, plug it into the ECU and have a full on Digital Dash. I did exactly that for testing/diagnosis on my set up
ODB-I will give you:
Injector Pulse Width
Coolant Temp
Speed
RPM
Throttle Posn etc
It used to be called "Monitor Select" on the now defunct VWRX site
But Brent Wiede has a linky:
http://www.weidefamily.net/vanagon/Files/B10ScanTool/b10scan.html
Building a TTL -> RS232 interface isn't too difficult
HTH
Edit:
Picture, from Brent's pages:
 _________________ The advice you receive on here is worth the paper it's written on.
graham-e Padawan
Posted: Mon Jul 19, 2010 9:51 pm Post subject: |
Interesting stuff..
Bought a car PC job off eBay for £30 so might have to give it a go!
Cheers  |
graham-e Padawan
Posted: Mon Jul 19, 2010 10:27 pm Post subject: |
Does anyone know If the signal from the sensor going to give the correct speed output signal to the ECU or Speedometer? Or will it need calibrating?
Thanks, Graham |
Posted: Tue Jul 20, 2010 8:54 am Post subject: |
If you're talking about the s/w up there ^^^.... when I did the maths, a Leggy has roughly the same tyre radius of a T2. It was something like 5% out IIRC
I can't remember exactly as it was a fair while ago
2πR
πD _________________ The advice you receive on here is worth the paper it's written on.
rjes Jedi Guardian
Posted: Wed Aug 04, 2010 10:31 pm Post subject: |
Yes. The sensor will drive an electronic speedo. I assume you mean an aftermarket, (i.e. multi purpose) speedo? If so, that's easy, as the speedo will have some calibration adjustment to account for different speed sensor specs and tyre sizes, and ytou will be able to set it using something like sat nav as a speed reference.
If you mean an electronic speedo from another production car, you will need to fit a speed signal calibrator between the sensor and speedo / ECU, and set it using an accurate speed reference such as sat nav. I can get the calibrators to order (actually I think I have one in stock somewhere).
If you are thinking of using a Subaru speedo, it needs to be from about 1998 or later (from a car with a 3 wire speed sensor screwed in to the gearbox, not a 2 wire sensor or speedo cable). Some of the other Subaru gauges (particularly the fuel gauge) are far more complex to get working correctly in a VW than the speedo.
The Brantz sensors which Elusive mentioned are intended for Vauxhall / Ford applications, and do not fit the VW cable properly. You have to modify the cable to make them fit. The sensors I stock fit with no mods. I stock sensors to fit bays and T25's, with two options on number of pulses per turn for each (4 pulses per turn is close enought to keep a Subaru ECU happy, but not accurate enough for the speedo). _________________ Regards,
www.rjes.com |
Doghouse Rielly Force Sensitive
Posted: Sun Aug 29, 2010 12:16 pm Post subject: |
I have seen beetles with dakota digital dashes
thinking of puting one in my bus they do a variery !
any one done this |
rjes Jedi Guardian
Posted: Sun Sep 05, 2010 2:31 pm Post subject: |
I'm not familliar with the details of the Dakota Digital dashes, but they more than likely need a digital speed signal, and have means of calibrating the display to suit the sensor built in. If so, the sensors I keep in stock should be suitable. _________________ Regards,
www.rjes.com |
