Baja IOM Wannabe
Posted: Tue Sep 07, 2010 10:43 am Post subject: Baja Bodykit, Wheels, Alternator, Glass etc. - SOLD |
- SOLD
I had to break a VW Beetle, I have kept these parts hoping to find a Donor vehicle but do not have the vehicle or the time to convert into a Baja Buggy, and now no longer have a garage in which to keep the parts so they have to be sold.
For those of you who don't know what a Baja Bug is: here are some pictues courtesy of [URL="http://www.oldbug.com"]http://www.oldbug.com[/URL]
The buyer will need to come to the Isle of Man to collect these in an Estate Vehicle or small van due to their weight and size. It could be boxed up but would probably cost more to send than if you came over on the ferry. It is a 2.5 hour Ferry trip from Liverpool (there is also a ferry link from Heysham, Dublin from Liverpool it costs around £242 (Return) for a vehicle with 2 passengers (See here for more info:[URL="http://www.steam-packet.com"]http://www.steam-packet.com[/URL] You could make a weekend of it and see the Isle of Man while you are here. The saving you will have made on these parts should make it a very cheap weekend/holiday
The Glass FIber Baja Bodykit includes; Rear Scoop, 4 x Wheel Arches, Bonnet, Side Bars (Not shown in photos), The is no front cowl (the part which fits under the bonnet, but these are available for £60), Rear Engine Cage/Bumper, Headlamps and Indicators are fitted to the front Wheel Arches.
The Body Kit is in reasonable condition, there are some light scratches due to storage but the parts will need to be rubbed down and resprayed when fitted to the vehicle anyway. This is a Solid Glass Fiber bodykit not flimsy rubbish.
Split 4 Stud Rim Wheels in Chrome, consisits of 2 very large rear wheels with Tyres, and the two smaller front wheels with Tyres, there is plenty of tread left on the rear Tyres, and tread on the front wheels, there is slight cracking on the rear tyres. The Wheels have been laquered, there are some very tiny rust spots around 0.5-1mm in diameter under the laquer. The laquer can be removed with paint stripper and the chrome polished with the the right polish, this should eliminate the rust for a mirror finish.
Other parts included are: Chrome Fan Shroud, Heavy Duty Alternator with Chrome Mount, Chrome Engine Fire Wall (Not shown in pictures), Chrome Dipstick, 2 Sets of Rear Lamps, and 1 set of lamp housings, Chrome Billet Style Window Winders, Clutch, 4 x Door Catches, 2 x Door Pins, 1 x Dash Moun Tachometer/Rev Counter, Oil Cooler/Breather with Braided Hose, Chrome Sump Cover, External Door Handles, Battery Terminals, Push Switch, Rocker Switch, Toggle Switch, 2 x Baby Turbo Mirrors, 2 x Wheel Spacers, Eyelets for Rally Seat Harnesses, Glovebox, Grilles which sit either side Speedometer. Rear number Plate Light, Fuel Filler Flap. Holder for Clock or Tacho.
Finally I have; One Piece Windows (not shown in the photos), Rear Side Windows including Rubber Trim, Rear Window and Rubber Trim, Front Windscreen (Flat Type, from 1302 Beetle) and Rubber Trim.
- SOLD |
