Hydraulic clutch solid line diameter.
PostPosted: Fri Nov 05, 2010 11:47 pm    Post subject: Hydraulic clutch solid line diameter. Reply with quote
Well just thinking out aloud on this one.... It's still not back together yet.
I bought the Saco hydraulic clutch kit which turned out to be no good for my application, well bits of it.
So as it currently sits I've used the Saco reservoir and the pipe supplied in the kit is the same size as the copper tube I used for my brake lines. Great as I had loads of this copper tube left over.
So I have used copper brake pipe to supply the clutch master cylinder fluid from the reservoir.
I used the brake pipe to supply fluid to the slave cylinder from the master cylinder.
The brake pipe is maybe 4mm OD. I've bleed it once already and the pedal was mega stiff, felt like something was gonna go if I really pushed it (long story short I felt it would be good to change my clutch arm and make a new bracket for the slave cylinder).
So my question is....
Could I benefit by increasing my hydraulic lines from 4mm to a 6mm copper pipe? I was told it would decrease the effort required to move the pedal.
I've used thread adaptors which have I would say small holes through them, if I increase the main pipes to 6mm should I be contemplating fitting adaptors with bigger bored holes through them?
If it's any use from memory I have a 19mm diameter master cylinder and a 22mm slave. No idea on the cylinder depths.
PostPosted: Sat Nov 06, 2010 9:38 am    Post subject: Reply with quote
4mm seems to small to me never seen one that diameter with all factory hydro clutchs they usually use 1/4" or 6mm pipe
P4UL
PostPosted: Sat Nov 06, 2010 10:49 am    Post subject: Reply with quote
The OD is a useless measurement, use the inside dia to measure as wall thickness will vary.
Personally I would have used the same size as the kit was designed to use, get it working then adjustment pipe sizes from there.
PostPosted: Sat Nov 06, 2010 11:20 am    Post subject: Reply with quote
I'm gonna bite the bullet and install a 6mm hydraulic line then. I've spent ages and ages f*****g around with this set up and I've bleed it loads of times now and each time it's just disappointing to see the end result. Im gonna redesign the bracket I've created for the mastercylinder too as it flexes a little too much when the pedal is depressed.
So my next Q
By increasing the line size to 6mm should I be changing the internal bore sizes of my thread adaptors?? They've an internal bore of maybe 2-3mm?
I have a flexy line in the system, should I be increasing the size of this too.
Think I'll pu it apart and get some measurements of all the items, I don't want to create a restrictive bottle neck in the system.
Thanks for all the replys people
PostPosted: Sat Nov 06, 2010 12:18 pm    Post subject: Reply with quote
My current line is 3mm ID.
PostPosted: Sat Nov 06, 2010 10:19 pm    Post subject: Reply with quote
if its proper clutch/brake pipe the internal diameter will vary very little brand to brand but will still flow fluid much easier than 4mm or 3/16" O/D
PostPosted: Sat Nov 06, 2010 10:25 pm    Post subject: Reply with quote
So my next Q
in my opinion i would change the adaptors and increase there internal bore and fit a new flexi hose with a larger bore (t25?) as all of these will be a restriction to the system
PostPosted: Thu Nov 11, 2010 11:21 pm    Post subject: Reply with quote
Woowho... Feeling alittle euphoric tonight.
So I've kept the small brake line (after buying 25 meters of 1/4") and actually got round to bleeding it this evening.
Well it only bloody works. The pedal is fairly heavy... How ever from memory it feels exactly the same as the old cable with KEP stage 1 or 2 pressure plate I removed. It's usable as is with the smaller line.
I'll still look into installing the larger line but that'll probably wait for the time being as ive got plenty more to be getting on with.
Cheers for all you help
