Help identifying kit... apparently ford conversion
Davecrook1
PostPosted: Wed Feb 09, 2011 7:28 pm    Post subject: Help identifying kit... apparently ford conversion Reply with quote
I have spotted this kit for a few pennies which im pretty keen on..
but it says its for pintos and cvh engines.. but not sure how it would go together.. where would my starter motor fit? apparently uses vw starter and input shaft...
Covin
PostPosted: Wed Feb 09, 2011 10:48 pm    Post subject: Reply with quote
No idea what kit that one is.
Starter motor would stay on your VW gearbox but I'm not sure about using the standard input shaft Can't see how it would still be long enough to fit into the crank bearing.
Most adaptorplate kits I've seen for Fords use release bearing spacer, ford starter and an extended input shaft.
DARREN
I LOVE RUST ME
Davecrook1
PostPosted: Thu Feb 10, 2011 7:52 am    Post subject: Reply with quote
How easy is it to replace the input shaft?
PostPosted: Thu Feb 10, 2011 9:57 am    Post subject: Reply with quote
Covin to the rescue again... CLICKY HERE
1983 VW Golf GTI CAMPAIGN
Covin
PostPosted: Thu Feb 10, 2011 11:29 am    Post subject: Reply with quote
You beat me to it JP
DARREN
I LOVE RUST ME
Davecrook1
PostPosted: Thu Feb 10, 2011 2:51 pm    Post subject: Reply with quote
Cheers chaps
Turboing a none turbo engine is too costly for me tbh.. I wanted an already turbo'd motor.
Pinto I suppose is the next best thing..
Davecrook1
PostPosted: Thu Feb 10, 2011 3:05 pm    Post subject: Reply with quote
But that unknown kit above still needs an extended input shaft? I asked the chap again and he said no, it should just bolt up to the gearbox.. But bare in mind he hasn't fitte it to the project he was doing
PostPosted: Thu Feb 10, 2011 5:31 pm    Post subject: Reply with quote
Mine uses the standard input shaft and a T25 Clutch Plate so sounds feasible to me.
Mine also uses the ford Starter which is a bonus.
I do have a spigot bearing that holds the shaft in the engine so to speak.
So I've got
Ford Flywheel
Ford Pressure Plate
VW Clutch
HTH
Davecrook1
PostPosted: Thu Feb 10, 2011 6:09 pm    Post subject: Reply with quote
mmm.. i have no idea what parts are in the kit above.. dont think he does either.. i think i'd need to use a ford starter..but he said vw..???
he wants 100 for that kit.. is it worth risking in buying it?
PostPosted: Thu Feb 10, 2011 10:08 pm    Post subject: Reply with quote
Did you try calling famous Phil for his kit in the for sale section? Personally I'd rather go with that set up and use the Ford starter.
Davecrook1
PostPosted: Thu Feb 10, 2011 10:20 pm    Post subject: Reply with quote
Sent him a pm earlier. Just waitin to hear back from
him..That other kit may be ok, but it's the not knowing if it'll fit which is the prob
Covin
PostPosted: Fri Feb 11, 2011 7:49 am    Post subject: Reply with quote
Yes, that's the other kit option rather than using an extended input shaft Wink
I've got a spare, complete Ford adaptor kit that I might sell so I'll try and get a picture for you today. Think it's a G B Engineering one
DARREN
I LOVE RUST ME
