slushrush Force Sensitive
Posted: Sat Feb 19, 2011 11:50 am Post subject: 1979 Porsche 915 Gearbox & EJ20 Turbo Subaru Engine |
Subaru EJ20 turbo engine converted to fit into a VW. Has been dyno'd at 217bhp and run a best 1/4 mile time of 11.60 in my race car. Everything is included to fit into a VW apart from the adaptor plate, included is the following:
EJ20 Turbo Engine
High pressure fuel pump and filter
Aluminium header tank
Reversed coolant manifold
Aluminium coolant pipes
Renault radiator and fan
Autometer water gauge
Charge cooler, radiator and pump
Stainless Steel exhaust system
Modified wiring loom by TSR
Also have Subaru clutch and flywheel so if you wanted to use the RJES bellhousing route you can.
£1100
1979 Porsche 915 low mileage gearbox from Pro 9 Porsche with front mount, clutch, starter motor, gearstick and gear shaft. To use this with a VW engine you need a flywheel from KEP and to modify the rear VW mount with some spacers.
The gear ratios are as follows:
3.86 R&P
3.18 1st
1.83 2nd
1.26 3rd
1.0 4th
0.82 5th
This gearing makes it very similar to having a T1 close ratio gearbox with 1st to 4th with a free way flyer gear in fifth. These gearboxes can handle 300bhp+
£1300
Would sell both together for £2200.
