Thick or Thin
splitbus67
PostPosted: Tue Mar 22, 2011 9:44 pm    Post subject: Thick or Thin Reply with quote
Just starting on a EJ20 conversion in our Split, so I've been reading up on the different radiator setups and was wondering if anybody had any advise on radiator thickness, would a thin core radiator (18mm) be better as it would offer less air resistance than the thicker duel core radiators which offer greater cooling surface area.
Also does anybody have any advise on the routing of the pipework between engine and rad on a split screen van.
Bundy
PostPosted: Tue Mar 22, 2011 10:15 pm    Post subject: Reply with quote
No idea on a split screen as mines a bay, but I'm doing the same conversion as we speak and have gone for thin rather than thick due to the restrictive flow already on a horizontal radiator...making it thick will just make it worse.
That said...mines still in construction so I can't comment on it's effectiveness!!! I'm using a Renault Master van rad...got the in and out at one end, pretty big and cheap on fleabay Grin
Where 'up norf' are you?
Al
ricola
PostPosted: Wed Mar 23, 2011 6:02 pm    Post subject: Reply with quote
Generally frontal area is more efficient than thickness of the radiator, but for a given installation, thick is more efficient than thin due to the bigger surface area exposed to the coolant.
There are diminishing returns on how thick you can go but that would be extremely thick before improvements stopped.
http://www.ricola.co.uk
splitbus67
PostPosted: Wed Mar 23, 2011 9:24 pm    Post subject: Reply with quote
Al, we are in Skipton North Yorkshire.
Al
Bundy
PostPosted: Thu Mar 24, 2011 4:43 pm    Post subject: Reply with quote
bit further up than me then Grin
Sunny Congleton, Cheshire for me!
Good luck with the conversion
Joel
PostPosted: Fri Mar 25, 2011 3:55 am    Post subject: Reply with quote
Like Ricola said the single row thin rads are more efficient, the only reason for double row thicker rads is space constraints
I've had both in my bug
My first rad was a single row mazda jobbie that had a core size of 15" high and 22" wide, it worked really well and only reason I ditched it was it took up too much boot space.
My new one is a double row Alfa rad
It's 22" wide same as the other but only 10" high so in terms of capacity it's about 30 % bigger than the Mazda rad but it actually takes longer for the fans to bring the temp down.
This is mainly due to the 2nd row not working as efficiently due to the heat from the first row and slower air flow through it.
It's also a cross flow rather than the top to bottom like the other which makes it slightly less efficient than the other but this wouldnt matter in a bus when its laying over flat.
If you have the space go thinner single row.
PostPosted: Sat Mar 26, 2011 8:31 am    Post subject: Reply with quote
what he said with multicore rads as the air travels through each core it gets heated by the last core so the thus the efficency drops on the later cores, ive got a 20mm thick rad on my tdi split and that keeps it nice and cool i'd say airflow through rad is more inportant than size
splitbus67
PostPosted: Sun Mar 27, 2011 8:10 am    Post subject: Reply with quote
Thanks gents, this is what I suspected, thin its is.
RatCamper
PostPosted: Fri May 13, 2011 11:27 am    Post subject: Reply with quote
I've got a 3 layer that disperses heat really well. True with diminishing returns, but brute force is winning.
