ecu ????????????
kev
PostPosted: Tue May 31, 2011 8:44 pm    Post subject: ecu ???????????? Reply with quote
evening all
thought i would take a look at the wiring this evening
i thought i had everything i need ecu transponder etc
but then i found this connecter {see pic}
my brother inlaw thinks its the fuel ecu unit
does this seam right and can i get hold of whatever it is
thanks for any help
cheers kev shaw
kev
PostPosted: Thu Jun 02, 2011 8:35 pm    Post subject: Reply with quote
Apparently it's abs connection
ping
PostPosted: Thu Jun 02, 2011 9:12 pm    Post subject: Reply with quote
Yep thats it. You wont need it. but if you doi've still got mine somwhere if you want it.
kev
PostPosted: Fri Jun 03, 2011 7:59 am    Post subject: Reply with quote
thanks ping
will keep that in mind if i need it but i doubt it on a camper van
